Old 01-09-2022, 08:19 PM
cdeggz cdeggz is offline
Originally Posted by togaflyer View Post
Did you pull the plug from your alternator and check to verify your getting 11.5 is volts at the plug. Just insure power is getting from the switch and/or breaker to the alternator.
Yes, confirmed that as well.
Dues Paid September 2021
Old 01-09-2022, 08:20 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Have you tried bypassing the regulator (short, temp test) like we use to do on our old cars?
Ed
Old 01-09-2022, 10:12 PM
Ed I like this idea. Are you thinking 12V straight to the field? I assume I would need to hook the output (b) up to something that is not the plane?
Old 01-10-2022, 06:01 AM
Mich48041 Mich48041 is offline
Instead of bypassing the regulator with 12 volts, just measure the field current.
Joe Gores
RV-12 Flying
Old 01-10-2022, 09:45 AM
Hey Mich. O was seeing a cure t on the field that matched the other alternator. I want to say it was a round 4 amps but I can’t remember exactly.
I guess that is the quick summary:
-Field current seen
-B-lead voltage only at 12 V
-no current from alternator
Those make it look like a faulty alternator, but:
-Alternator shows 7 ohms
-alternator turns with the engine
Which makes the alternator sound like it should be working.
Seems pulling the alternator for further inspection is warranted.
Old 01-10-2022, 10:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Craig------as you are also having ignition issues as posted in another thread, I would look for any common link between the two.
Start with the grounds, my $0.02.
It might be time to bring in someone experienced in electrical systems to take a look at your plane.
Good luck, let us know what you end up finding.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-10-2022, 12:37 PM
Paul Paul is offline
Hey Craig,
My 40 amp breaker on the power supply from the alternator had popped and I reset it but had the same type of issue and could not track it down.
Found that there was no continuity across the 40 amp breaker !
Breaker replaced and all was good
Paul
RV-6A Flying Since 2002
"Taylor Maid"
Kansas City, MO
Old 01-10-2022, 02:55 PM
N49ex N49ex is offline
Default Alternator failure, can’t find cause.
-Field current seen
If you are seeing 12V at the output, that means the breaker is good and you are seeing the backfeed from the battery, and it is not rising above the static battery voltage because the alternator it in fact not putting out current. Before pulling it out, as others have said, you could force it in place- it's ok to put 12V on the field, disconnect the output from the plane, and put a decent load on the output, something like a heater or a pair of 12V light bulbs in series (with 12V on the field it would put out more than 14V!), and see if it puts out anything. That is the dirt-simplest configuration which should ferret out for sure if the alternator is bad. B&C would probably fix it readily at that short age....
Old 01-10-2022, 05:57 PM
Recheck the "B" lead voltage at the alternator. But this time connect a high
wattage lamp in parallel with the voltmeter. Expect to see battery voltage.
A load such as a lamp will make problems show up better.
The alternator might NOT be turning fast enough if the drive coupling is slipping.
Field current of 3 or 4 amps is reasonable.
Joe Gores
RV-12 Flying
Old 01-11-2022, 10:54 AM
PilotjohnS PilotjohnS is offline
Default Grounds
As was alluded to earlier, there may be common issues that point to something other than alternator.
I would check all the grounds from engine to firewall to battery to alternator's regulator.
Just my $.02
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 70%
