Old 12-20-2021, 07:20 AM
BrianMatice BrianMatice is offline
Default VariPrime 615S - Discontinued - Need Alternate
I love VariPrime self etching primer. I can prime with Variprime in the dark, and it comes out great. I can hit it with a hammer and it wont come off. If you have been a long time user of VariPrime I suspect you love it too. I got some devastating news the other day from my paint supplier, that VariPrime 615s has been discontinued. Nooooooo!!!!!!!!!
They told me the direct replacement is Axalta 420. I bought some and tested. After scuff with scotchbrite and washing to remove oils and drying 24 hours I can scratch it of with my fingernail just as easy as dried mash potatoes on a plate. In fact, the dried potatoes stick better than this stuff does.
anyway to the point of my post. Has anyone out there found a good replacement for a Self Etching Primer, as good as VariPrime????
Brian Matice
C-150
Building RV-7A
Riverview Florida
Old 12-20-2021, 07:25 AM
bjdecker's Avatar
bjdecker bjdecker is offline
I've had good luck with SEM Primer -- https://www.semproducts.com/product/self-etching-primer
Scuff, clean with acetone or alcohol, and apply. Dries in < 5 minutes.
Brian Decker
RV-7 (Flying)
Old 12-20-2021, 08:32 AM
PhatRV PhatRV is offline
Have you considered using epoxy primer?
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
Old 12-20-2021, 08:43 AM
wirejock's Avatar
wirejock wirejock is offline
Default Mashed potatoes
... In fact, the dried potatoes stick better than this stuff does.
How about thinned mashed potatoes? Sorry. Couldn't resist.
Lots of choices. SEM for rattle can self etch.
Akzo or Kirker Enduro Prime for 2K Epoxy
P60G2 for super light wash primer
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 12-21-2021, 10:09 PM
Mikeyb Mikeyb is offline
I’m pretty sure nobody would use rattle can primer if they ever sprayed some 2-part epoxy. When I was building the empennage for my -8 I tested two of the popular spray can primers and AKZO epoxy on identically prepared aluminum samples and tested them with tape adhesion tests, bending with a dimple die and resistance to solvents. I wish I would have documented it better but there was no comparison. The epoxy was much, much better in all of these tests. Not the same ballpark or even league.
Old 12-22-2021, 07:17 AM
spark68 spark68 is offline
Default Epoxy
I settled on two part epoxy after trying several rattle can primers early in my build. The adhesion and resistance to scratching are superior with the epoxy and makes the extra effort worthwhile. My preferred brands are Southern Polyurethane (SPI) and Tampco Paint. Product quality is good and cost is less than the big name companies.
https://tamcopaint.com/
https://www.southernpolyurethanes.com/
Mark Curley
RV-6 status: finish kit
dues paid 2022
Old 12-22-2021, 09:38 AM
Another decent epoxy primer is Stewart Systems's EkoPoxy. It's water-based and water-thinned. Quite tough. I clean the spray gun in the sink under running water.It dries to the tough pretty rapidly.
I'm using it for my cockpit and baggage areas, white for good maintenance or loading but dark gray where it might reflect to the canopy of my RV-3B. Elsewhere I'm using SEM rattle can primer, which is also decent. The SEM does not require a spray gun or cleaning the gun afterwards.
Dave
Old 12-22-2021, 10:51 AM
BoydBirchler BoydBirchler is offline
Variprime has always been my favorite. Ditzler made a good etch primer called DP which contained lead and was replaced with DPLF; LF means lead free. The problem with DP is it needs to be scuffed and a new coat applied if not finish painted over, within I think 60 days
Old 12-28-2021, 02:42 PM
sailsunfurled sailsunfurled is offline
Default VariPrime
Brian,
While searching for VariPrime I came across this thread. I see where you had info that this is discontinued but I found this link for VariPrime http://products.axaltacs.com/dcat/us...duct/615S.html on Cromax's website.
I found a source local to me, is it the same product your refer to as Variprime you have been using? I want to check with you that it is the same product before I spent a few $$$ on it.
Scott Arnold
