Go Back   VAF Forums > Regional Forums > Canada
Old 02-17-2021, 04:47 PM
Stickkers Stickkers is offline
Default Primer-What are Canadian builders using for Primers?
Hi guys, Iím just wondering what you guys are using as a primer and where are you buying it from? Thanks
Old 02-17-2021, 05:52 PM
terrye terrye is offline
PPG Super Koropon
http://www.ppgaerospace.com/Products...terior-Pr.aspx
Both companies I bought from years ago are no longer in business
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 02-17-2021, 06:13 PM
Ron B. Ron B. is offline
Stits EP-420 Aircraft Spruce
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 02-17-2021, 06:47 PM
Weefle Weefle is offline
Rustoleum self etching primer ...... rattle can from Home Depot.
Keith
____________________________________________
RV-10 in progress
CGMMD reserved
Dues paid till 2022
Old 02-17-2021, 07:06 PM
RandyAB RandyAB is offline
Akzo Noble from ACS mostly. I’ve sprayed some small parts with self etch. No comparison for durability. The epoxy primer is magnitudes better in that regard.
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 02-23-2021, 02:05 PM
stigaro stigaro is offline
Stewart Systems EkoPrime. Water based so it's very easy to clean up and as a result, I don't mind using it for small batches of parts. Durability seems good, especially on interior parts. Only thing I'd recommend is to go a dark color so you can see it when sprayed. I used Smoke Grey which looks too similar to unprimed aluminum and so is difficult to evaluate coverage.
RV-14A
Empennage - 95% complete
SB Wings - ordered
2021 Dues paid
Old 02-23-2021, 02:21 PM
Jetmart Jetmart is offline
Sherwin Williams P60G2 purchased at the local Sherwin Williams paint store. They had to order it in. Took about 2 days.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Started October 22, 2019
Engine, prop, and cowling to complete
2021 Dues Paid
Old 02-26-2021, 12:56 AM
Aero_Octaveus Aero_Octaveus is offline
Pro-Form Primer from the local Napa/Auto Body supply shop.
I've been using primarily pro-form 1K self etch primer in rattle cans for matting surfaces. Using Pro-form 2K epoxy primer for high abuse areas. RandyAB is spot on for durability..the epoxy primer is way more durable but its heavy. So use wisely.
I did an extensive primer durability test before my build (in my build log). Learned lots.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
Old 02-26-2021, 04:14 AM
Tom Martin Tom Martin is offline
Test primers with Av gas to check for suitability. No sense priming your wings if the first spill washes off your primer.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
