Old 02-16-2021, 09:31 AM
Dan---we've used -3 teflon for injector lines, mainly on SDS systems. These are on a IO390 with SDS and a baffle mounted fuel block. Similar idea for a flow divider.
Tom
Click image for larger version
Name:	INJECTOR HOSES V2  1.jpg
Ridgeland, SC
Old 02-16-2021, 10:12 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Tom
I have ben looking at those on our neighbor’s project - man, are they slick...and beautiful!!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-16-2021, 10:34 AM
DanH's Avatar
DanH DanH is offline
Well 'ole buddy, it sounds like a product idea. However, I think we would want -2 lines to minimize the fuel quantity boiling out the open nozzle into the intake port after shutdown. Not a problem with the SDS application, as the injectors park with the pintle closed.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-16-2021, 03:25 PM
-2 teflon is hard to find, and pricey. When we need a -2 hose, such as for primer or older oil pressure/fuel pressure installs, we convert our -3 straight hose ends to -2. Same -3 hose, same stems, we turn the bodies and the flareheads down on the lathe so the -2 nuts will clear. The 471-2D stem ID is .060, our -3 stem after crimp is .079.
Works well.
Tom
Ridgeland, SC
Old 02-16-2021, 04:55 PM
scsmith scsmith is online now
Works well.
Tom
DanH's idea is to reduce the internal volume as much as possible. Just changing the ends doesn't do it. Even if the -2 line is pricey, a bunch of us might happily pay it to avoid this cloud hanging over.
I look mine over every time the cowl is off. I have seen one break on a Maule.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 02-16-2021, 05:47 PM
blaplante blaplante is offline
Default time between replacement?
Assuming the failure at 1470 hours was with well secured lines... perhaps replacing the injector lines every 1000 hours would be advised?
RV6A in phase 2 as of April 2016
Donation made Oct 2020
Old 02-16-2021, 08:03 PM
Plummit's Avatar
Plummit Plummit is online now
If you have a plenum, looking the injector lines over doesn't happen very easy.
-Marc
RV-10
N814RV
2021 Donation Made
Old 02-16-2021, 10:10 PM
Steve--I think Earls might be the only other source for -2 hose ends, and they are reusable. $50.00 EACH for 1 straight. 45* is like $75.00, and 90* is $87.00. Each. These are block style, heavy.
That takes care of the flow divider side, where you can substitute a AN816 nipple (usually AN816-2 is aluminum). Doesnt fix the injector side.
On another note, I do have some prototype -2 ball seat primer/flow divider fittings in straight and 90* that I messed with several years ago. Big issue is the nut, and making the stem small enough for the nut to pass over, without changing the nut alot.
Can be done though
Tom
Ridgeland, SC
Old 02-16-2021, 11:07 PM
Stewbronco Stewbronco is offline
Default Happily pay !
Heh Tom ...I wholeheartedly agree with Steve ...would happily pay for -2 lines fir this application!
Old 02-19-2021, 07:50 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Can be done though
Tom, any more word or progress on this? How realistic or difficult would it be for you to produce braided lines for direct replacement of the stainless FI lines?
RV-7 Flying since 2004
1,100 hrs+
