Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 12-30-2020, 03:30 AM
kjelle69's Avatar
kjelle69 kjelle69 is offline
Default Holes on the back of Propeller hub
See attached file, I have a Pacesetter propeller which have two holes on the back of the hub, anyone who knows what the purpose of these holes is? Balancing?
One is filled with resin and the otther one partly filled with a grey-ish glue.
________________________________________
RV-4. O-360A1D/180 with Pacesetter 200 Prop.
Old 12-30-2020, 05:01 PM
Aerodon Aerodon is offline
I have an aluminum prop with a spacer. There are two locating dowels, on opposite sides, but not exactly between the adjacent holes.
Aerodon
Old 12-30-2020, 05:22 PM
rocketbob's Avatar
Its for balancing. A few wood prop manufacturers do it this way.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-30-2020, 05:34 PM
PaulvS's Avatar
PaulvS PaulvS is offline
If the holes are for balancing then I wonder why are they not symetrically opposite each other? Wouldn't it be more efficient for the prop manufacturer to sand off a teeny bit from the blade rather than drill a hole that is so close to the hub.
I don't know the answer and probably it doesn't really matter other than for curiosity, but I thought that perhaps the holes are tooling holes from the manufacturing process.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 12-30-2020, 05:55 PM
BoydBirchler BoydBirchler is offline
Pacesetter is a great performing prop, the best fixed pitch I have ever flown behind!
Old 12-30-2020, 07:05 PM
Mel's Avatar
Mel Mel is offline
You cannot balance the prop until it is complete, including the finish. If you sand after finish, then you have to refinish. Now you have to balance again.
See the vicious circle that has started?
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-30-2020, 07:06 PM
Mel's Avatar
Mel Mel is offline
Ever flown behind a Catto?
Old 12-31-2020, 12:26 PM
theduff theduff is offline
Default Wood Props
I have and flown behind a metal FP as well as a variety of wood props. Warnke’s both Bernie and Margy, Pacesetter, Sterba and Performance Propellers both Clark and Frank’s versions. I can say that they all have there +’s and -‘s but a properly built wood prop has a special feel to them, hands down smoother than all of the others. Don’t knockem till you try’em !😁
RV-4S (slider) Builder and 1300 hr RV Pilot
Old 12-31-2020, 01:06 PM
rvbuilder2002's Avatar
I think Catto props are made using a wood core(?) so they probably fall into the same category, but I agree with your comment.
I was the first RV-6(A) builder to put one of Clark's Performance Propellers 3 blade props on my 6A in the early 90's. Every other RV owner that ever flew in it with me always mentioned how it felt turbine smooth (and we didn't even know what dynamic balancing was back then)
Scott McDaniels
Hubbard, Oregon
Old 12-31-2020, 01:29 PM
rocketbob's Avatar
Because they are balanced laterally as well as on the longitudinal axis of the propeller.
N8155F C150 flying
