Go Back   VAF Forums > Model Specific > RV-14
Old 01-14-2021, 12:26 PM
rjkulesa@gmail.com rjkulesa@gmail.com is offline
Default Anyone else having problems searching the “RV-14” forum?
Hi all,
I keep running into an issue that when i search this RV-14 forum, it only returns results going back to early December. I’m not using any filters and when I check “From any date” is selected. If I search a topic across ALL forums, I get result going back to 2006, except the RV-14 returns are only up until early Dec.
Ive tried different browsers and computers with the same results.
For example, I’m looking for additional info on what folks have done in regards to when they riveted thier bottom skins as I’m thinking I’ll build the ailerons and flaps, then work on Sect 23 (aileron actuation) and install roll servo/AP (then maybe uninstall the rods) before riveting bottom skins.
So i search “Bottom skins” and only get RV-14 results thru 06Dec2020.
Thanks.
Rich K.
RV-14A Kit #140477
http://www.rkulesa.com/category/building-a-plane/
Empennage Complete
Wings in progress
Old 01-14-2021, 02:24 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Me too
Seems Like every time I do a search and specify the RV 14 forum I come up with zero results which I find hard to believe based on my search criteria. Glad I’m not the only one that has come across this.
Mark
RV-9A; Built, Flown & Sold
RV-14A; Building
2021 =VAF= donor
Old 01-14-2021, 02:42 PM
ColoradoSolar ColoradoSolar is offline
Originally Posted by rjkulesa@gmail.com View Post
Hi all,
Thanks.
Don't know if this will effect search but do you have your display options to be from the beginning?
I hardly ever use the search in the forum I use Google. If you append "site:vansairforce.net" it will only search VAF. I usually include something like "RV14" or "RV14A" in the search to try and limit it. I do not know a way to search a specific forum using Google.
Eric Vickery
RV-6A Tip-Up Bought Flying
Old 01-14-2021, 03:20 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default software upgrade
There is a known problem with the forum software and the search function is not working properly. DR is aware of it and has purchased the new software and is going to install it when he has the opportunity.
In the meantime Google is the best alternative for searching VAF.
[ed. What he said.... v/r,dr]
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 01-14-2021, 03:35 PM
Thanks for that update! I just was trying to avoid raising a question that has definitely come up before. I’ll try the google route .
Rich K.
RV-14A Kit #140477
Empennage Complete
Wings in progress
Old 01-14-2021, 05:33 PM
Jetmart Jetmart is offline
I find google works better on most forums. Usually type the forum name and then the question. Comes up with more accurate search results.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Started October 22, 2019
Engine, prop, and cowling to complete
2021 Dues Paid
