Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 12-27-2020, 06:32 AM
RV6-KPTW RV6-KPTW is offline
All good advice. What works well for one may not work for you. I did not like the swivel head. I felt I had better control with a fixed head on the gun.
Only thing to add here is practice kits are cheap. I did a bunch of the Vans practice kits until my quality was acceptable. It was educational to compare the (was it 6?) completed versions from start to finish.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/18/2020 * 2
Old 12-27-2020, 07:02 AM
BillL BillL is offline
Default Where does this "scrap" come from?
Originally Posted by Roy25101 View Post
just recently ordered an RV-14 empennage kit and am trying to come up with ways to make this an easier build than previous kits (none of which have I finished). One of my biggest problems previously was riveting. If I can pop it, squeeze it or back rivet it then it comes out quite well. But, if it has to be pounded, in can be an issue. My question to you is do you have any recommendations for any tools that may be helpful in the process. I see some folks using swivel mushroom sets, sets with rubber skirts, long sets that look like foot long rods, etc. What I have used in the past is a small tungsten bucking bar as well some other various shaped steel bars. Although I have had decent success with these the main issue is consistency. I’d love to hear any techniques, videos, tools, etc. that might help. As always, thanks so much for your time and input….
Pneumatic driver (bucking) was the most difficult for me to yield consistent results. You always hear "just use some scrap" . . . .so is that expensive original parts that got damaged?
Call Vans, I think they generate a lot of "scrap" aluminum - see if they have packages of this for purchase. I think they do. It will the the correct thicknesses. Then practice, practice, practice, with a known matrix of things you want to try. One thing I found that made a difference was the stiffness of the structure being riveted. Then you have air pressure at the gun, I like a regulator not a restrictor. Using rivet tape, checking each dimple to ensure the rivet is not choked. etc.
Then - use a off set and get good at that with universal heads.
It was really fun to learn all the tricks .
Funny story, I dropped in for the tour at Vans factory. They closed early so had to go back -but that is another story. Sterling gave me the cooks tour and we went out back and I saw the huge scrap bin. I think drooling was exhibited, but said wow what do you do with that? He said a salvage guy came to pick it up. My response (probably like every builder) was you should package a bundle and sell that to builders!! A lot more money than pennies a pound.
Bill
RV-7
Lord Kelvin:
Old 12-27-2020, 07:18 AM
mturnerb mturnerb is offline
All builders should keep a photo of Van's scrap pile in their shops, in order to feel better about themselves!
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 12-27-2020, 07:30 AM
Mel's Avatar
Mel Mel is offline
Difference being that, Van's scrap is leftovers from making parts. Builder's scrap is generally from destroyed parts.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-27-2020, 07:56 AM
Taltruda Taltruda is offline
I would echo the advice to get a mentor or two and try their different techniques. What's the point of practicing the wrong thing and getting good at making a mess?
Tom
Las Vegas
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 12-27-2020, 01:41 PM
I knew someone would point that out. However I did once get some J-channel from them that was "backwards" (holes in curved part, not flat part), so they do make mistakes on rare occasions....
Turner Billingsley
Old 12-27-2020, 04:45 PM
You know you are improving your skills when the scrap pile begins to get smaller and smaller as you make things from them, it?
Bill
RV-7
Lord Kelvin:
Old 12-27-2020, 06:01 PM
FireMedic_2009 FireMedic_2009 is offline
Default Remember there is a pressure adjustment on the rivet gun
When I first had to use a rivet gun the person handed it to me with the pressure turned way too high. I didn’t know any better and used it for awhile screwing up a few times until someone else told about the pressure adjustment and what a difference and way more controllable
RV-6A IO-320 FP sold
Donated 2018 and continue annually
Old 12-27-2020, 06:10 PM
wirejock's Avatar
wirejock wirejock is offline
Default Drilled
J-channel drilled? Whooda thunk? None of mine was cut or had holes!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 12-28-2020, 04:59 PM
Roy25101 Roy25101 is offline
I want to say thanks for all the great advice. I even got an offer locally for some hands on training. Perhaps I'll post some successful riveting pictures before too long... Y'all are awesome!!
