Old 01-09-2021, 04:35 AM
rmartingt's Avatar
Default Infinity grip “default” button config from Spruce?
Looking at possibly buying my grips from Spruce instead of directly from Infinity, but trying to figure out how much rewiring I’d need to do...
What is the default configuration of the buttons on the “with flap/brake” option, in terms of momentary vs. on/off pushbuttons? The website is not clear...
Old 01-09-2021, 07:08 AM
622BH 622BH is offline
Default My Experience
Albeit 7 years ago, there is no "default" you tell them what switch configurations you want in each location. There should be no need for re-wiring.
Old 01-09-2021, 07:19 AM
rapid_ascent rapid_ascent is offline
Yeah its hard to tell from the website. Most people want a flaps switch on the stick, but you'll probably will have to call them. I originally purchased mine from them as well, but I don't recall how I made the selection. I recently actually changed out my flap switch to be momentary in both directions. These switches are not cheap so its best to get the correct configuration from the start.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 01-09-2021, 08:10 AM
Raymo's Avatar
Raymo Raymo is offline
I used the flap grip option, which requires a relay to control them. The other buttons are:
Trim hat
Black: AP disconnect (mom)
Green: Radio flip/flop (mom) [wouldn't bother again]
Red trigger: PTT (mom)
Blue: Not used (on/off). I tell newbees that it is the missile launcher
You can purchase replacement switches from ACS to replace what comes with the grip.
Ray
Old 01-09-2021, 08:22 AM
rmartingt's Avatar
Disregard, Raymo answered the question as I was typing.
Thanks!
Adding: I’ve actually found frequency flip-flop very useful, but that’s because I’ve been exposed to a lot of formation flying...
Old 01-09-2021, 08:25 AM
Super Moderator
The last few times I ordered them from Spruce they came with switches that were not momentary, so it required a changeout of most of them.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 01-09-2021, 08:27 AM
rmartingt's Avatar
Vic
Good to know, thanks... maybe it’s worth just ordering direct then...
Old 01-09-2021, 11:36 AM
Default Suggestion
I suggest you go to Infinity website and download the switch / ordering form. That lists all the options available. Next, think about how you want to use the stick switches and after giving it much thought, order the options you desire.
After several years of use for my original selection, I decided I didn't need one function but wanted another in it's location. So I ordered the appropriate switch, opened the grip unsoldered the old, soldered the new; closed it all up and have been flying the "new" configuration for at least three years.
Will I want something different later? Maybe, and if I do, I know I can change to whatever fits my flying need (desire) at that time.
