Old 12-28-2020, 02:10 PM
JDBoston JDBoston is offline
Default Countersunk wrong side of thick piece
I have an email out to support, but am thinking through the ramifications of my latest mistake and wonder if this is salvageable without part replacement. This is from the fuselage page 25-05 and is the bearing bracket.
https://imgur.com/BbSxEnj
It is a thick piece, and a universal head (ad4) will be going in that hole. The backside is countersunk and behind that is another thick spar piece. The way this happened is that I prepped two chapter's worth of parts and didn't look closely enough at which of the web holes they were talking about for this piece. Luckily this is the only real mistake.
Thoughts?
Jeff
RV-14A
Status: Tail mostly complete, Wings complete(ish), Working on: Fuselage Kit
http://vans14a.blogspot.com/
Old 12-28-2020, 02:59 PM
Ron B. Ron B. is offline
Not an engineer and you should pass this suggestion through Van's, but could you drill out three rivets leaving a hole in the tapered part of the rivets with no stem? Like tapered bushings and glue them in the counter sinks holes to fill the holes , then put the called out rivets through the assembly ? Just a thought where as there is plenty of material for strength.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-28-2020, 03:05 PM
Taltruda Taltruda is online now
Another option is to move on to other jobs, add this to a list of replacement parts, and next screw up, you buy both parts to combine shipping! I don't know where in the build this part is, and it looks small, but you know it's not correct, even if it may turn out structurally ok, you know it's there. .
Tom
Las Vegas
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 12-28-2020, 03:07 PM
Thanks Tom. That's my usual way of working, and I totally agree. I stopped to think on this one just because it's a thick piece on both sides surrounded by lots of bolts and screws. I am about to click on reorder anyways and was curious about this kind of situation in general with thick material.
Jeff
RV-14A
Old 12-28-2020, 03:35 PM
Bavafa Bavafa is offline
I wonder how one can drill into the head of that tapered part for the rivet to pass thru?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-28-2020, 03:37 PM
Using a lathe? Drill the hole, then turn a taper, then part it off?
Tom
Las Vegas
Old 12-28-2020, 06:08 PM
Why not just put the stem of a rivet in a lathe and drill a 1/8" hole in the head until it parts from the stem?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
