Old 01-19-2022, 11:56 AM
Ralph Inkster Ralph Inkster is offline
Default Vans RV Numbers in Canada
RVs are fairly popular here & I wondered what our numbers actually were. So I figured a quick search through the Transport Canada data bases could cook up a quick survey, but... I soon realized the actual data lines were based on Registered Owners, not aircraft... and there wasn't consistency in Make and Model fields (eg. RV6A called by a different name) to do a clean search. These numbers are understated because I wasn't going to go thru a huge editing effort to get closer to actual counts, but it gives you an idea of how many RVs are flying up in the Great White North.
I gathered these numbers during my morning coffee break, If you have more time (& inclination), you could get the real & larger count.
----- RVs - owners
AB - 133 - 160
BC - 141 - 162
ON - 207 - 185
PQ - 66 - 75
the balance of RVs reside in the rest of Canada's provinces & territories
total CDN - 609 - 710 - so there at least 710 RV fanatics (plus a bunch of builders) up here
It was gratifying to see registrations for RVs I've built & owned over the years. It was also interesting to see RV partnerships out there. I thought 2 or 3 partners would be normal, but there is an RV-10 listing 6(!) partners - there should be some good stories from that!
So, why is it still, about every 4th airport I land at that someone will walk up ask 'What's that you're flying?' ??
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 01-19-2022, 09:21 PM
Weefle Weefle is offline
Interesting numbers Ralph. I had no idea there were that many. I know in Vernon here there are quite a few.
Hopefully next year one more RV 10 will be added to the numbers.
Keith
____________________________________________
RV-10 in progress
CGMMD reserved
Dues paid till 2022
Old 01-20-2022, 07:40 AM
kearney kearney is offline
Ralph
It would seem that you are personally responsible for a significant portion of the Canadian builds!
Les
RV10 C-GCWZ Sold and now vacationing in Tulsa
RV10 C-GROK Flying
RV10 # 3 - under construction
*** Dues Paid ***
Old 01-20-2022, 07:49 AM
Snowflake's Avatar
And if you're searching, you'll also have to include all the RV's that are registered as a "Joe Bloggs Model 1" and not as anything you'd recognize as an RV...The builder is the manufacturer, and the builder can call it whatever they want to...
Rob Prior
Old 01-20-2022, 09:00 AM
Yep. If someone's RV was listed "Hummdinger-6A" or such in the Model field, it's not in my count. It would take much longer than my morning coffee break to catch all the unique names & add them in...
Ralph
