I wonder if those of you who have an injected engine and use the Air Flow Performance electric fuel pump (as supplied by Van's) can answer a couple of questions?
Has anyone mounted the pump forward of the firewall? and
Has anyone ever found any debris in the filter supplied with the pump?
I am considering not fitting this filter (as it seems rather coarse and expensive), and using an Andair firewall mounted gascolator instead. That means I will either have to fit the pump after the gascolator (forward of the firewall), or fit the pump in the Van's suggested position but with no upstream filter. Any thoughts?
Pete
Pete
