VAF on Twitter:
@VansAirForceNet
  #11
Old 11-12-2021, 11:44 AM
Originally Posted by 00Dan View Post
Don’t the current Van’s cowls also require an extension? I know my old fixed pitched Van’s cowl on my -4 requires a 4” extension, and I think the CS cowl required a 2.25” extension.
The standard kit supplied cowls are designed for use with the Hartzell compact hub propellers.
When a fixed pitch propeller is used instead, a 2.25" extension (actually spacer) is required.
Prior to developing a cowl designed for use with the Hartzell compact hub prop., the cowls required a 4" spacer be used with a fixed pitch prop, or the use of the extended hub version (approx. 1.75" longer than the compact hub) of the Hartzell propeller.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips,
ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR, EAA Technical Councelor
Old 06-06-2022, 08:42 PM
AlphaCharlieBravo AlphaCharlieBravo is offline
Default Saber Manufacturing
Just received my 4" Saber Prop Extension for my extended James Cowl and Lycoming A1A engine and it is a work of art. Beautiful!
Going with a three blade Catto prop. Spoke to Nicole the other day and getting that order in this week.
Arnie
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
