Old 09-13-2021, 08:32 PM
rvator4twa rvator4twa is offline
Default Weight and balance
Anyone have a program for the 6A?
Ron Burnett N524RB
RV-6A Lycoming O360 dual EFII system 32
Vinyl wrap-tired of polishing
M71-Greensfield, MO near St. Louis
USMC combat exempt but dues gladly paid April 2021
Old 09-13-2021, 10:17 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Some good hints here:
https://vansairforce.net/community/s....php?p=1102695
Also, if you use a tool like foreflight, it can be set up for your W&B, but you need an accurate W&B done on your aircraft - your friendly local A&P can do this, or perhaps your local EAA chapter guys can help with some scales.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 09-14-2021, 05:32 AM
MacCool's Avatar
MacCool MacCool is offline
I recently had my airplane simply re-weighed. The weights OTOH were pretty far off compared to 2011 when it first flew and listed in the POH. I combined the exercise with the fact that I needed to replace the tank and sump drains, some of which had the drips, and drained all of the fuel. So I was able to re-establish a new "empty weight" as well as then re-calibrating my fuel level sensors and fuel computer by adding fuel back two gallons at a time. Kind of a nuisance adding two gallons of fuel then climbing in and out of the cockpit 18 times, but illuminating.
Once I had the weights, I assumed that the moment arms were all the same as the POH and just entered that data into the W/B portion of Foreflight...works great. Also found several airplane-specific Excel spreadsheets around the internet and re-formatted the best of them with my own data. I put it into my Dropbox and can now access the W/B data from whatever Excel-containing device I happen to have convenient.
RV-9A, 2011, bought flying
IO-320D1A
IFR certified
AFS 5400/3500, G5, 430W, some other stuff
