Old 03-26-2009, 07:56 AM
chaskuss chaskuss is offline
Default LED Replacement for Incandesent Bulb
Listers,
I have been given two Military style Soderberg cockpit/utility lamps. Similar lamps were also made by Grimes. My lights look like the one in the link below. See
http://www.soderberg.aero/products.p...=1&prod_id=580
I really like the utility of these lamps. I would like to bring them up to the 21st century by replacing the incandescent bulbs with LED replacements. I know that some manufacturers are making LED bulbs with either a bayonet or screw in base, so that they can be used for replacement of standard incandescent bulbs.
Can anyone direct me to a web link or manufacturer who might be able to supply me with LED bulbs for these lamps?
Any suggestion for LED replacements of other common aviation incandescent bulbs would also be appreciated.
Charlie Kuss
Old 03-26-2009, 09:05 AM
captainron's Avatar
captainron captainron is offline
Kinda heavy and bulky head-bangers. Wouldn't something like this be better?
http://www.aircraftspruce.com/catalo...ckpitLight.php
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 03-26-2009, 09:14 AM
mburch's Avatar
mburch mburch is offline
For what it's worth, Steinair (and other outfits) sells a nice looking LED light that mounts and works approximately the same way:
http://www.steinair.com/lights.htm
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
Any opinions expressed in this message are my own and not those of my employer.
Old 03-26-2009, 11:29 AM
Default I'm not changing
Guys,
I appreciate your attempts to steer me towards a more modern product. However, the Soderberg lamp has features that I want. I would simply like to update the older incandescent bulb with a newer style LED.
Charlie
Old 03-26-2009, 11:53 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try contacting Soderberg, they offer a LED light with a replaceable bulb, that might fit your unit.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-26-2009, 12:08 PM
Good luck.
Mike,
The lamp in your link won't work. The LED unit is a cartridge and it's 28 volts. I did send Soderberg an email with my request. Thanks for the idea.
Charlie
Old 03-26-2009, 12:42 PM
DGlaeser DGlaeser is offline
Default LED replacement bulbs
Maybe one of the 12v bulbs these folks offer would work (?)
http://www.superbrightleds.com/1157.htm
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-26-2009, 01:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile This one should work...
Originally Posted by chaskuss View Post
Mike,
Charlie
...as a LED replacement for a 1816 bulb...
http://www.brite-lite.com/Products/LEDminiatures.html
...under the T-3 1/4 section.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-26-2009, 02:17 PM
Default Thanks
Gil,
I've been searching the Internet for an hour. I found several vendors, but not one with an actual part number for the bulb. Thanks for the link.
# 5100-09-144-004 is what I need.
I did learn that the 1893 bulb is a substitute for the 1816 (1893 is 14 volt, 1816 is 13 volt)
Charlie
Old 03-26-2009, 08:34 PM
kcameron kcameron is offline
Default I'm happy with my Perihelion map light
It's lightweight and very adjustable.
http://www.vansairforce.com/communit...ad.php?t=40433
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying
IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
