Old 11-21-2019, 10:34 PM
Driftdown Driftdown is offline
Thank you, Scott, for the clarification.
Old 11-22-2019, 06:05 AM
Deuelly Deuelly is offline
So, regard less of whether he built or bought this LSA, if he didn't take the course required, his inspections aren't valid and the plane is unairworthy?
Old 11-22-2019, 07:10 AM
jnorris's Avatar
jnorris jnorris is offline
Every aircraft that holds a special airworthiness certificate (including all experimental and SLSA aircraft) will have operating limitations as a part of the airworthiness certificate. Those operating limitations will contain the requirement for inspections and who is authorized to perform such inspections. Typically, the inspection interval will be 12 calendar months. But as has been mentioned previously, this is not universal so you must read your operating limitations to verify the requirements.
Now, for amateur-built and ELSA, the operating limitations will contain the ability for a person holding the appropriate repairman certificate to perform the condition inspection. Who is eligible for these repairman certificates will vary between amateur-built and ELSA.
For amateur-built, only the "original primary builder" is eligible for the repairman certificate for that aircraft. Who can qualify as the "original primary builder" is the subject for a different discussion. The point here is that there's no way for anyone other than the original primary builder to gain the repairman certificate for that aircraft. If you're not the original primary builder, the common choice is to have an A&P mechanic perform the inspection.
For ELSA, a person who is the "OWNER" of the aircraft must attend and successfully complete a 16 hour course of instruction in order to gain the appropriate repairman certificate. This is true whether you are the builder of the ELSA or not. Even if you built it, you must successfully complete the course in order to gain the repairman certificate. The benefit here is that subsequent owners of the aircraft are also eligible for a repairman certificate for that aircraft after completion of the course. So an ELSA is attractive for a second or subsequent owner from this perspective.
In any case, if someone is performing condition inspections on an experimental aircraft without the appropriate repairman (or A&P) certificate, the inspections are not valid and the aircraft is not legal to fly.
Cheers!
Joe
Old 11-22-2019, 08:00 AM
jrtens's Avatar
jrtens jrtens is offline
Just to clarify - if you build or buy an RV-12 ELSA, you may do any and all maintenance on your plane. You may not however sign off the annual condition inspection unless you have taken the 16 hour course and obtained a LSRI certificate from the FAA.
If you do not want to do this, then you will need to get an A&P or a LSRM to perform the condition inspection.
Jon
12iS SLSA #5
Salt Lake Int'l
Old 11-22-2019, 08:48 AM
NinerBikes NinerBikes is offline
As an owner of a RV-12, then if you are the 2nd or later owner of an E-AB build, then, unless you already HAVE your A&P, or the 120 hr course, you will be paying annually for someone else with a valid A&P to do your annual inspections.
Any idea how many hours an A&P will spend doing an annual and what it would cost a potential owner considering buying a used E-AB RV-12? Concerned more about how much it adds to the cost of annual operations for budgeting purposes.
Old 11-22-2019, 08:49 AM
Mich48041 Mich48041 is offline
Regardless of any education or courses taken, the person signing the
logbook for the condition inspection of any E-AB or E-LSA aircraft must hold a
repairman's certificate or A&P certificate. The certificate is issued by the FAA
and looks similar to a pilot's license.
Anyone may work on or maintain an E-AB or E-LSA aircraft, even a young
teenager whose only experience is using a cell phone.
Joe Gores
RV-12 Flying
Old 11-22-2019, 08:56 AM
Security is a little tight at the airports I frequent, the teenagers getting into the hangar areas is a unheard of nowadays since 9-11, compared to the 1970's and 1980's where you could hang out at an airfield and learn a lot.
Old 11-22-2019, 09:13 AM
jrtens's Avatar
There is quite a difference between an E-AB RV-12 and an ELSA RV-12. Most RV-12s are ELSA. Is that what you mean?
Jon
12iS SLSA #5
Salt Lake Int'l
Old 11-22-2019, 09:27 AM
joe gremlin's Avatar
joe gremlin joe gremlin is offline
120 hr course?
Old 11-22-2019, 10:54 AM
Originally Posted by joe gremlin View Post
120 hr course?
Correct me if I am wrong, but I believe you need to take a 120 hr course to get your A&P Certificate? Someone here, set me straight.
