Need Source for AkzoNobel TR-19 Thinner
KJP
Member
Hi Folks,
I can't find a source for this primer thinner. ACS does not have it and Graco has a $250 minimum order for this gallon of thinner.
Any suggestions?
Thank you.
MEK for thinner
If you are using it for the green AkzoNobel 2 part epoxy primer, I used MEK worked fine and after the primer sets up its tuff. Scrubbed with alumiprep and scotchbrite rinse let dry and prime.
