Bluetooth connection issues with remotely mounted cameras
Rvator97
Active Member
Patron
If anybody out there is knowledgeable about Bluetooth technology, can you explain why remotely controlled, (via Bluetooth), wing mounted cameras work only on the ground? My Insta 360 remote control device loses the bluetooth connection to camera shortly after takeoff...every time!
The camera is mounted on a pole that extends out in front of wing. There is a clear line of sight to the remote in the cockpit, which is only about 10 feet away......????
