Scarbrough
Member
Need some advice on installing an air filter coalescing system. I am just starting the build and want to do it right. Not concerned too much about using filtration for painting at this point (I'll use a HVLP system). I went on Amazon and there are alot of systems to choose from. Any advice on what has worked for this community would be much appreciated. Thank you all so much.
