w/a Donation
VAF on Twitter:
@VansAirForceNet
  #91
Old 06-28-2021, 01:21 PM
jcarne's Avatar
jcarne jcarne is offline
Glad it worked out Ivan!
Jereme Carne
CFI
RV-7A Flying as of 03/2021
Old 08-03-2022, 10:29 AM
agent4573 agent4573 is offline
Empty Weight: 1189
Empty CG: 79.62
Full paint, fire extinguisher, full Classic Aero interior, IO-375, 2 qt oil accumulator, Whirlwind 300 prop, full Garmin glass, 6 quarts oil in the engine, 1.5 in the accumulator.
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 08-08-2022, 11:34 PM
griffg griffg is offline
Default W & B
R/H Main Wheel 426 lb (193 Kg)
L/H Main Wheel 444 lb (201 Kg)
Nose Wheel 240 lb (109 Kg)
Total Weight 1,110 lb (503 Kg)
Empty CG 82.07 in (2084 mm)
The weight on the nose wheel is on the light side which is caused by the Catto composite propeller and spinner plus the EarthX lithium battery. Though I do have a Saber 16 lb Crush Plate (i.e. a 20 lb one with a hole machined in the middle for the Catto spinner) retaining the prop which has compensated but not to the level I was expecting.
The CG is further back than I was hoping which has limitations in relation to luggage and passenger weight with minimum fuel on board.
So back to the options available. One option is to replace the EarthX battery (i.e. weighs 1 Kg) with the heavier Odyssey PC 680 battery (i.e. 7 Kg) which is an easy weight gain option.
Gordon Griffin
RV-7A - beginning test flying
VH-NAK
IO-360-M1B
Catto 3 blade prop
Old 10-15-2022, 03:29 PM
motodave motodave is offline
V2:
Empty weight: 1,115
Empty CG: 77.89
Left: 532
Right: 528
TW: 55
Empty it is forward of CG but with any weight added (for example 5 gal & 100 pilot which is not me!) it falls within range and will give me full loading options.
“Chino” paint job - I.e primer fiberglass and bare aluminum, James cowl, extended hub Hartzell, leather seats, full carpet, slider Sika bonded. Was hoping for under 1,100 but happy with the loading options. Hard to get out CG range as it stands. DAR inspection Thursday then fly it!!!
Dave
RV7 Slider N732DH Flying!
YIO-360-EXP Thunderbolt
Garmin G3X panel w/VPX
Littleton, CO & KCFO (aka CO Air and Space Port)
Photo log: https://flic.kr/ps/9jjZz
