Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-16-2023, 04:37 PM
RV10 Grove versus Beringer Wheels and Brakes
 About to order an RV10 kit and wanted some input on the wheels and brakes. Any recommendations on which ones Grove or Beringer? What is the difference?
09-16-2023, 05:14 PM
I’m a big fan of Grove personally.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, AFP FI, MTV-9 prop
09-16-2023, 06:07 PM
Location: Spring Hill, FL part time Central Ohio the rest
Primer War
We all like what we are using especially if it's served us well. Only human instinct. For me I like the tubeless aspect of Michelin tires on Beringer wheels. Plus, with Beringer they use Sens Air which allows me to monitor temps and pressures without physically checking. (Bluetooth) Only need to add air every 6 months. 425 hours on the mains and brake pads. Nose wheel looks like it will go 750 hrs +. Absolutely no shimmy. Results may vary.......
RV-14A - TB390, Garmin G3X, EarthX, Beringer Wheels & Brakes, B&C alternators, Flying Aug 2020. Evoke Paint. RV-10 - TB540, Garmin G3X, EarthX, Beringer Wheels & Brakes, B&C alternators, Flying hopefully Spring 2024. Want to build and fly the 15 as my last Vans airframe.
09-16-2023, 06:58 PM
Suggest you research the brake energy and torque ratings of the various choices and make your decision in an informed manner.
Run the numbers on an RTO at rotation speed at the maximum gross weight you plan to “certify” at and see which of the brake choices meet or exceed your needs.
I did and chose Matco. The Beringer ratings were acceptable too, but I couldn’t justify the cost delta versus Matco. The Beringers have some other benefits/features that might make them worthwhile to you.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021) - now at her new home in Lakeville, MN
RV-10ER Phase 2. In paint at Evoke! Penn-Yan IO-540, dual bus SDS EFII, Hartzell composite prop, Showplanes cowl, Airflow Systems A/C, Garmin IFR panel by SteinAir, Aerosport interior, carbon fiber panel and overhead console, Mountain High O2
EAA Technical Counselor
09-16-2023, 08:47 PM
This^^^^
What Krea said…
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
Paint by Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2022,...Thanks DR+
09-17-2023, 06:50 AM
Super Moderator
I’ve had Matco on my RV-10 for almost 2300 hours. Plenty of stopping power when needed. We’ve installed them on many other 10’s as well. The price is great, too.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, Hummingbird helicopter, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft", "Are your Nuts Tight?" &"Maintenance Guide for Vans RV Aircraft."
www.Baselegaviation.com
09-17-2023, 07:13 AM
Meh. All the systems work—IMO you can’t go wrong with any of them. You’re not stopping a fully loaded 747. I’ve got Grove and they work just fine.
PP ASEL-IA
RV-10 N728TT - Flying!
EAA Lifetime Member
WAR EAGLE!
09-17-2023, 07:26 AM
I disagree
Funny you should say that - my first job out of college was with Boeing as a Flight Test Engineer working primarily with landing gear and brakes.
I think you might find that the stock brakes are marginal to potentially inadequate on a fully loaded RV-10 (especially with an increased gross weight above 2700 lbs) and even more so after a long taxi at a high density altitude airport.
It’s not hard to run the numbers. Matco even provides a brake energy calculator here - https://matcoals.com/technical-support/how-to-choose/
Try it out and then look up the specs on the brakes you are considering.
Krea Ellis
Locust Grove, GA
09-17-2023, 08:02 AM
Rv10 brakes
I’ve got grove on my 10.
700 hrs works perfect.
Great company.
A&P,
RV conditionals & prebuys.
Still Love and flying my RV10
Built: two 7s, Three 8's, two 9As,10,12, RANS S7; Assisted in 2 RV14As
RV Jackpoints mfg'r "wintermotorsports.com"
When does a repeat offender stop????
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
