w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-17-2023, 06:01 PM
Ruready Ruready is offline
if its like the denso that bandc sells than 17 bucks gets you a new connector and a bunch a wire https://bandc.com/product/replacemen...-h-sk35-lom30/
Click image for larger version
Old 09-17-2023, 08:13 PM
agent4573 agent4573 is offline
Originally Posted by Aerodon View Post
Not so sure about that. The externally regulated has 2 wires, pin 2 is jumped over to pin 3. Same connector.
The internally regulated alternator seems to have one wire, I have not found a decent drawing showing which pin this is connected to. I assume the field, pin 2, but would like to verify.
Don
There's 2 pins connected on the internally regulated alternator as well. The field wire comes out and goes to your field power supply, the sense pin is connected to the field wire. Even though it's internally regulated, you still have an external sense pin in case you want to sense battery voltage instead of alternator output voltage. Most people just leave it jumped and don't worry about the 0.1-0.2 volt drop between alternator and battery.
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 09-17-2023, 11:25 PM
jliltd's Avatar
jliltd jliltd is offline
It is not like that. That appears to be a Molex-style molded plug. The one PP uses is more of a WeatherPack Denso OEM type connector as shown in the attached photos. You can see the little red silicon seals/strain relief inserts in the photo of the wire side of the plug. Those were missing from the original plug in our PP alternator kit.
ID:	48144  Click image for larger version
Jim Ivey
RV-8
Old 09-18-2023, 02:31 AM
Looks like the BandC LX60 connector $20. https://bandc.com/product/replacemen...460-h-bc462-h/
ID:	48149  Click image for larger version
Old 09-18-2023, 07:55 AM
Pounder's Avatar
Pounder Pounder is offline
Talking Solutions Abound
Thanks all...
Yes, this is the "three prong" connector. (I have yet to upload pictures here... I need to grow up).
Recapping:
- Jump # 3 and #2. They connect to field switch.
- #1 to (optional) "alt fail light".
- This alt has internal regulator.
- Pigtail from spruce for $100 plus, or auto parts (amazon) varieties, $10-20.
And the PDF install manual(s) actually are all available. Needed to cross reference model number as read off the data plate to Hartzell's list. This required a call to Hartzell Eng Tech folks. Very responsive.
As for actually downloading the PDF from Hartzell, previously I could not access via safari. I had to download and use google chrome. (because we wouldn't want to be excluded from big brothers behavioral data base :-)
Love this group..
Now, launching a new thread to get air/oil separator opinions from the braintrust..
VR/
Bryan
RV-8, mostly
Plus Projects galore
