Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-16-2023, 03:17 PM
WTB Plane Power Alt Connector
For some reason, I am not able to find a connector for a Plane Power alternator.
Allen at Hartzell said he'd send one, but no joy after a few conversations.
I cannot find a part number to save my life.
Maybe someone out there in van-o-sphere can give me a vector.
VR/
Bryan
RV-8, mostly
Plus Projects galore
09-16-2023, 04:23 PM
Originally Posted by hgerhardt
+1
...and make sure to use the little rubber boots on the wires.
Brian Decker
EAA Technical Counselor
RV-7 (Flying)
09-16-2023, 08:57 PM
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
09-16-2023, 10:35 PM
If you go to Autozone or Orielly's get the smartest employee there (sigh) and explain it is for an early 90's Nissan 300Z. But take your old plug with you or a photo if you can. We just did this and bought the pigtail version and spliced the wires (you have to combine two of them in a Y to replace the original jumper). PP didn't install the silicon strain relieve boots originally and so the original contacts fatigued and broke.
Jim Ivey
RV-8
09-17-2023, 05:45 AM
Hartzell gave me P/N 11-1010
Spruce has it as 1010S. I'd be careful, there might be a difference between the internally regulated alternates and the external ones?
Part# 07-18001
MFR Model# 11-1010S
09-17-2023, 06:47 AM
Plane Power/Hartzell: $116. Autozone $20. Both with pigtails. The one from Autozone has silicon strain relief. Plane Power original didn't, leading to failure.
These plugs are only for internally requlated Japanese automotive alternators, which Plane Power rebrands. If if there were worries about internal or external regualtors you are just replacing a plug and as long as you keep the wires straight no problem either way.
Jim Ivey
RV-8
09-17-2023, 08:34 AM
[quote=jliltd;1712781]If you go to Autozone or Orielly's get the smartest employee there (sigh) and explain it is for an early 90's Nissan 300Z.
Thanks Jim. That should do the trick.
VR/
Bryan
RV-8, mostly
09-17-2023, 12:10 PM
I went to the local ‘auto electric’ shop, he said it could be one of three choices on a Denso alternator, he had a bin full of each.
Ralph
Now retired - my builder assist shop now closed,
09-17-2023, 03:42 PM
Not so sure about that. The externally regulated has 2 wires, pin 2 is jumped over to pin 3. Same connector.
The internally regulated alternator seems to have one wire, I have not found a decent drawing showing which pin this is connected to. I assume the field, pin 2, but would like to verify.
Don
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
