w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-10-2023, 01:55 PM
KatanaPilot's Avatar
KatanaPilot KatanaPilot is offline
If they turn out to be RV-8 flaps and there will be a big delay getting replacements from Van’s, I do have a pair of QB RV-7 flaps. Email me if interested.
Krea dot Ellis at gmail dot com
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021) - now at her new home in Lakeville, MN
RV-10ER Phase 2. In paint at Evoke! Penn-Yan IO-540, dual bus SDS EFII, Hartzell composite prop, Showplanes cowl, Airflow Systems A/C, Garmin IFR panel by SteinAir, Aerosport interior, carbon fiber panel and overhead console, Mountain High O2
EAA Technical Counselor
Old 09-10-2023, 02:50 PM
toolmanmike toolmanmike is offline
Default RV 8? 7? 9? flaps??
Gents, I believe I may have the wrong flaps!!!
Click image for larger version
Name:	flap leading.jpg
this is the width of my flaps at the Leading Edge =58" at the rivet line
Name:	flap trailing.jpg
This is the width at the trailing (uncut) end = 61"
Now please tell me the 7 and 8 Ailerons are the SAME?? I have attached a pic of mine. 54" at the widest.
Name:	aileron width.jpg
MBurch- I measured center of rivets to rivets but the inboard rib is on a diagonal. So the measurements would vary depending on where you go from. However, all my measurements were longer than you stated.
Toolman
Toolmanmike
PA, USA
RV-7 sn75068
Emp done.
Wings done
Fuselage-?? Working on it!
Dues paid
Old 09-10-2023, 03:06 PM
Ralph Inkster Ralph Inkster is offline
"Now please tell me the 7 and 8 Ailerons are the SAME??"
Nope. Looks like you have 8 flaps....
Ralph
Now retired - my builder assist shop now closed,
Old 09-10-2023, 03:10 PM
agent4573 agent4573 is offline
My QB ailerons were labelled 7/8 so I think you're safe there. Was there not a part number on your flaps when they were delivered?
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 09-10-2023, 03:11 PM
TShort TShort is offline
My -8 aileron measures the same, 54”
Note my measurement above for my -8 flap is the entire length of the trailing edge, as built (slow build). Wings are not mated to fuse yet so the flaps are untouched.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 09-10-2023, 03:22 PM
Mel's Avatar
Mel Mel is offline
Default Discrepancy??????
Huh? Question seems to be about ailerons, Answer is about flaps.
Mel Asberry, DAR since the last century. Over 1,100 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-10-2023, 03:31 PM
PhatRV PhatRV is offline
I don't know the difference between the -7 and -8 flap.
But on my RV8, when I first fitted the flap to the fuselage, the inboard end was a bit too long, maybe from 1/4 to 1/2 inch. I had to carefully trim the end so that the upper flap skin is contoured to fit flush with the curvature of the fuselage. The picture is the finished product and there was about 1/16 gap between the upper skin of the flap to the fuselage skin.
So in summary, my -8 flaps were a bit on the long side and I had to trim them on both sides.
RV8 (N38PV)
Days to First Flight: 999
Old 09-10-2023, 03:45 PM
RV7 & 8 ailerons take same spar so are the same.
RV7 & 8 wing rear spar webs are the same, difference being a longer riveted on tab on the 8 where it bolts to the fuselage.
That longer tab & fuselage shape difference requires a slightly longer flap on the 8.
The OP was originally discussing FLAPS, so my prior reply was based on FLAPS, I didn’t note he was now questioning AILERONS..,
Ralph
Old 09-10-2023, 04:07 PM
mburch's Avatar
mburch mburch is offline
Originally Posted by mburch View Post
My RV-7 flaps measure roughly 56.5" between the rivet lines of the inboard and outboard ribs
Sorry, I should have specified that I was measuring between the aftmost rivets (widest dimension between end rib rivet lines).
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
Any opinions expressed in this message are my own and not those of my employer.
Old 09-10-2023, 04:24 PM
Stevea Stevea is offline
Default flap skin trim required?
Uhm, don't the 7 and 8 have the same wing....therefore the same ailerons and flaps? (Sorry, don't have 7 or 8 prints to look at drawings.) The only difference would be how the flaps are trimmed where they meet the fuselage.
My 6 flaps required trimming at the fuselage end. Of course...that was way back in the jurasic build era when we had to smelt our own aluminum.
Steve Allison
RV-6A - sloooowwww build
First flight - 3/8/14
Phase II - 5/19/14
