Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
06-28-2023, 08:05 AM
May have happened on startup, from excess priming. Not a backfire but a front fire.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Tech Counselor
06-28-2023, 08:18 AM
Plus one for this...
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
06-28-2023, 08:22 AM
I can predictably trash a filter like this with one false start backfire. Most always I can tell it happened, but it does happen on start, usually when everything is cold.
Just like the previous post said, over rich on start and the flow reverses thru the intake, deforming the filter upward. Mine is a little more secured than yours (mine is not exactly per plans, added some retention not called for), but the shape of the filter folds are almost the same.
My new technique (you learn faster after $45 penalties) is to prime less and feed the mixture in during the start. Not 100% but it's working pretty well to avoid this issue.
BTW The filter will hang in there and do the job for a long time after this happens, but seeing a waffled filter in my intake path gives me the heebies thinking about where the trash might end up if it comes apart ...
Cheers
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
 - Been there, Donated 2023
06-28-2023, 11:33 AM
well aware of what a backfire is, but you are going to have to explain what a "front fire" is. Not in the mechanical vocabulary I learned from.
06-28-2023, 03:51 PM
Filter
Ryan
Would you post the Auto Parts part number please.
I like to keep a backup and can't find the original box.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
06-28-2023, 04:41 PM
Originally Posted by wirejock
Ryan
Larry,
The part number on the one that came with my snorkel kit is K&N 33-2060. The best price I found online was at the actual K&N store if you don't need it the next day. All the local autoparts stores I called needed to transfer it from another store. https://www.knfilters.com/33-2060-re...ent-air-filter
Ryan Drake
Cameron Airpark, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2022
RV-7A (N12VD)
Never give up on a dream just because of the time it will take to accomplish it. The time will pass anyway.
06-28-2023, 04:55 PM
Pretty sure its not a backfire
No way this is a backfire. During my phase I on an RV-14A, I had something similar....not exact but similar. I had squeezing that deformed the air filter bracket hold down. The problem was with the RV-14, you build up the cowl to add a rubber flange to seal off the air box. My build up was a little excessive and it created a squeezing effect on the air box. I inspected everything carefully and removed some of the flox build up and re-positioned the rubber flange and it relieved the "squeeze" and I've had another 50 hours on the airframe without any more squeezing. I am confident that you will find this has nothing to do with a backfire and everything to do with cowl fitting and such. good luck
06-28-2023, 05:08 PM
Air filter
Originally Posted by Draker
Larry,
Thanks Ryan
Larry Larson
Estes Park, CO
Disclaimer
06-28-2023, 07:33 PM
Larry,
Before I learned and practiced the mixture sweep method of hot starting a Bendix injected Lycoming, I got a "pop" or explosion in the intake on a couple of occasions due to igniting fuel in the intake of an overly flooded engine. The filter looked exactly like the OPs image. Replaced it once, bent it back once.
Never had an another issue since using mixture sweeping.
Bill Pendergrass
ME/AE '82 Retired.
RV-7A: Flying since April 15, 2012. 980 hrs
YIO-360-M1B, mags, CS, GRT EX Horizons & A/P, Navworx
06-28-2023, 07:48 PM
Yoda says
There is no front-fire. There is backfire, and there is after-fire.
Choose one, you must.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 80 hours
66 years running stock DNA
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
