w/a Donation
VAF on Twitter:
@VansAirForceNet
  #521
Old 05-26-2023, 04:04 AM
jliltd's Avatar
jliltd jliltd is offline
Originally Posted by Dozer View Post
I would like to share about my experience with ordering an aluminum panel through Xometry. They have charged me around 300$ inculding a delivery fee from Mexico.
So, I just uploaded my STEP file of the panel, clicked the button Order and in 3 weeks later I received a panel. It was very easy. I really like the quality of their laser cutting and tolerance. All the holes on the panel have been designed with the tolerance +0.2 mm to the actual diameter of the switches, LEDs (every single item was measured with a caliper during engineering process... Don't TRUST the drawings provided by manufactures!!! ) And the actual diameters on the panel I received are exactly +0.3 mm
Dozer. Since you are using a laser cutting service you have the option of having them leave a tooth inside the switch and breaker holes for indexing and keeping them from moving. I even do it when there is a keyed magneto switch. So no extra switch locking holes or indexing washers are needed for the components. Attached is an example of the hole configuration I am talking about. I have these laser cut and it works out really well. I do have to do a little bit of slag clean up with a small file but it only takes a few seconds. Both methods (holes or indexing teeth) yield very professional results.
Click image for larger version
Jim Ivey
RV-8
Old 05-27-2023, 05:35 AM
trischbieter trischbieter is offline
Default Weight
Curious if you know the weight associated with the complete setup?
Timothy Rischbieter
RV7A purchased and sold
RV10 purchased 1016, sold 2021
RV7 Flying
Dues paid 11-2023
Old 05-29-2023, 05:48 AM
Dozer Dozer is offline
I like a hole for a washer with a pin. But if someone really need to have a tooth, make it bigger and then file it to specific size. Laser unable to do very small teeth (they are melting at the tip).
But the reason I like those extra locking holes - my panel is a sandwich (aluminum base + fiber carbon overlay). And I don't make locking holes in the carbon fiber panel.
Old 06-17-2023, 12:33 PM
DCBrown198 DCBrown198 is offline
Not the best pic but you get the idea.
Dual Dynon HDX 1100, Dynon Comms (2), Garmin GPS 175, Garmin 340 Audio Panel. Not shown on left side...E-Mag dual electronic ignition switches.
I have no VHF nav radios. The Garmin GPS-175 gets me around in IFR. I've flown a few flights in IFR weather and have never missed that VHF Nav capability.
Old 07-06-2023, 07:59 PM
mark manda's Avatar
mark manda mark manda is offline
Thinking about attending Airventure for the first time in fifteen years to celebrate Rv10 anniversary
Old 09-02-2023, 07:40 PM
Jesse23 Jesse23 is offline
Aerosport symmetrical panel, all Garmin, remote com 2 behind luggage bulkhead.
2 E-Mags. Last pic I moved the AP head down where glove box was. Can fly right/left seat wo issue to panel layout. VPX Pro for circuitry.
ID:	47380  Click image for larger version
ID:	47381  Click image for larger version
Bill RV 10 N2722W
Based KBKV
https://eaa1298.com
Old 09-03-2023, 06:15 AM
Dad's RV-10 Dad's RV-10 is offline
Pics rotated:
ID:	47400 Click image for larger version
RV-10 - Built by my father. Undergoing upgrades/completion
RV-7 - Purchased
Old 09-03-2023, 10:15 AM
Thanks Brad for the rotation fix.
Bill RV 10 N2722W
Based KBKV
https://eaa1298.com
