Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
05-12-2015, 11:07 AM
I had good success making metal fairings by following the method described in the 21 Years of the RV-ator, "Aluminum Windscreen Fairing". No English wheel needed (even though I have one in the shop).
The only trick is measuring exactly the angle between the upper deck and the windscreen every two inches and bending the lower fairing flange to exactly those same angles.
The lower fairing is made from 2 pieces of 12" x 36" .025" 2024-T3 alclad. The upper fairing is made from one piece of 12" x 72" .032" 2024-T3 alclad.
Both fairings are bonded to the windscreen with Sikaflex-295i UV adhesive.
Jim Ellis
RV-7A, N23VC, Slider, Garmin G3X Touch Panel,
Barrett Precision Engines Superior XPIO-360,
Dual P-Mags, Airflow Performance FM200A,
Classic Aero Designs Interior,
GLO Custom Aircraft Paint,
Flying
RV-9A, N155T, Sold
Reason: Repaired broken photo links.
05-12-2015, 11:43 AM
Originally Posted by Jim Ellis
I had good success making metal fairings by following exactly the method described in the " 21 Years of the RV-ator", no English wheel needed (even though I have one in the shop).
Very nicely done. I riveted and screwed mine and then used Sika as a sealant only. It was in the early days before folks where doing the Sika thing.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
05-12-2015, 05:01 PM
I had good success making metal fairings by following the method described in the " 21 Years of the RV-ator", no English wheel needed (even though I have one in the shop).
That looks great! I'm in the process of repairing mine with carbon fiber but if I could start from scratch there is no doubt I would try to find somebody that had the ability to do as you did with the aluminum . The weakest point with fiberglass is at the top where the canopy closes to the windscreen plus people including myself sometimes either grab the top edge or hit it with there feet while exiting then it breaks off.
A C Tyler
RV 9A
05-12-2015, 05:46 PM
Originally Posted by rwtalbot
They claimed that when I used it too. I may have had a bad batch. However, these days I only use West Systems and make my own.
It is a polyester filler, and they all shrink - just some faster than others. Better to use micro with epoxy. It just does not set up as fast as the poly esters.
I am considering aluminum too, it is in the 6/97 RVAtor. You should buy the CD version all 27 yrs - searchable too!
Bill
RV-7
05-12-2015, 06:04 PM
"Old school" metal fairing. Although not necessary, as shown in Jim's fine work above, the "Wheel" allows you to put a small arc in the bow to slightly better match the windscreen/canopy intersection and add rigidity. It also allows you to ruin some metal as you get to learn a new skill! (Especially with 2024T3)
.032 with .040 bow, sealed with a layer of Sika under.
Bucker Jungmann
RV1 - Proud Pilot.
05-12-2015, 06:46 PM
I did a bit of a hybrid. I used aluminum over the top of the roll bar, which extends back over the slider portion of plexiglass. However, I used glass and epoxy for the fairing between the top fuse skin and the base of the windscreen.
What I did differently from typical was to lay it up on the fuse, but remove it for finishing. I put it back on for good when it was essentially ready to paint. I used a few pop rivets, and a layer of epoxy to seal it to the fuse and windscreen. I do not have a decent picture of it to post, but I'd do the same thing again. Sure makes getting it finished easier, and the seams between it and the fuse and windscreen are good places for expansion when necessary.
Alex Peterson
RV6A N66AP 1800+ hours
KADC, Wadena, MN
05-12-2015, 06:56 PM
Winshield Fairing
Hello Gents
Anyone with an RV-4 has pictures of their front fairing (On how they finished the front of their canopy )??
I will have to redo mine on my incoming canopy replacement and I'm looking for ideas..
On my previous and present canopy, I re-used the old fiberglass fairing and reglassed it in place but this time around I will be redoing the complete canopy and will be using the old one in the meantime..
Thanks in advance
Bruno
rv4@videotron.ca
05-12-2015, 08:46 PM
Originally Posted by drone_pilot
Looks nice, Crabandy! Did you use an English Wheel to do any forming?
Nope, simple tools I had/made/slightly modified. I would love to get an English Wheel and play around....
I think page 12 of my build log shows most of it:
http://www.vansairforce.com/communit...=94648&page=12
Good Luck!
(I saw all the excellent craftsmanship after I posted this, nice work in everyone's pics!)
RV 7 650 hours and counting
22’ donation done
05-13-2015, 03:57 PM
I used the 21 years of the RVator method too. I like the results and it only took 2 work sessions on one weekend.
Bill Pendergrass
ME/AE '82 Retired.
RV-7A: Flying since April 15, 2012. 980 hrs
YIO-360-M1B, mags, CS, GRT EX Horizons & A/P, Navworx
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
