w/a Donation
VAF on Twitter:
@VansAirForceNet
  #41
Old 04-15-2021, 07:39 PM
skidookid skidookid is offline
Default Rear rudder pedals rv8
Could I get a copy of rear rudder pedal set up thanks roger rwtsc@hotmail.com
Old 05-25-2023, 03:24 PM
Webb's Avatar
Webb Webb is offline
While waiting on a part from Vans to continue, I decided to make rudder pedals for the rear.
The button will be cut off and the rod threaded with a rod end bearing. Also the middle bracket will be eliminated reducing the chance of bending the rod.
I went to the ACE Hardware aviation section and picked up a bronze bushing and a steel sleeve. Being frugal, I repurposed the steel hinge bracket that came off the HS from the service bulletin. Brazed the steel sleeve to the bracket I cut in half.
The pivot is like an aileron bracket using the bushing and sleeve. Once the pedal is clecoed in place I’ll be able to determine where to attach the rod end bearing.
In the event I don’t want pedals back there anymore, I can pull the bolt and out it comes. And re-install is easy.
And of course some non skid tape will be added.
I looked thru the posts and didn’t see any others it like it. I’m hoping it won’t rub the seat cushion. If it does, I’ll make an improved version. After all, this was my first attempt and a few hours spent doing some I enjoy.
Click image for larger version
ID:	42877  Click image for larger version
Webb Willmott
KJVW
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
Old 08-26-2023, 03:56 PM
Webb's Avatar
Buttons, buttons, whose got the buttons………not me
ID:	47073  Click image for larger version
Webb Willmott
KJVW
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
Old 08-27-2023, 10:04 AM
Webb's Avatar
Default Pulling it all together
Here are my new rear pedals combined with the folding heal lifts. One is up and the other folded away.
The only snag I ran into is the idler arm is leaning slightly outboard and should be leaned more inboard to give clearance for the rudder cable and the mid cabin brace. Guess I didn’t see it when drilling the inboard hole on the mounts. Easy fix and replace mounts are inexpensive for the do-over.
ID:	47098  Click image for larger version
Webb Willmott
KJVW
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
