w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 09-10-2023, 07:40 PM
camillodinucci camillodinucci is offline
Default Ballistic Parachute for the RV8
Hello, I am finishing the assembly of my RV-8 and I intend to perform acrobatics with it. It turns out that I am very tall 2.00 meters height and weight 100 kg (220 lbs), being tall limits the possibility of using a parachute on the back or even a seat because when gaining height in the seat my knees hit the instrument panel when commanding the rudder pedals.
Having explained all this, I decided to install a BRS parachute in the RV-8, analyze the efforts in the structure and carry out the installation of reinforcements, the calculation of the CG, etc.
This was the way I found to perform the acrobatics with a little more tranquility.
If you could share your experience installing these devices, I would like to know more, and how the RV-8 performs afterwards.
Below are the project photos.
Name:	Captura de tela 2023-09-10 222501.png
ID:	47774  Click image for larger version
Name:	Captura de tela 2023-09-10 222600.png
ID:	47775  Click image for larger version
Name:	Captura de tela 2023-09-10 222551.png
ID:	47776  Click image for larger version
Name:	Captura de tela 2023-09-10 222745.png
ID:	47777  Click image for larger version
Name:	Captura de tela 2023-09-10 222827.png
Name:	Captura de tela 2023-09-10 222836.png
Old 09-10-2023, 07:49 PM
rmarshall234 rmarshall234 is online now
Greetings,
That is quite the project you are considering. Butler Parachutes in the US has made “ lap “ type parachutes in the past. If you haven’t given up completely on the idea of a PEP, you might want to contact them and see if they can help you.
Good luck.
Robert Marshall
RV-3 - 500hrs
A&P / IA
Parachute Rigger
Acroduster SA750 - finished!
Old 09-10-2023, 10:21 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I like your project and I had the same problem with my RV8. If I had anyone in the rear seat I could only fly with 5 gallons of fuel if I wanted to stay in a legal W&B envelope.
Sadly sold my RV-8 but still enjoying life by living on my airport with FREE campsites & facilities for all visiting pilots to enjoy while I putt-putt around in my Wilga while I wait for some used RV-15 to hit the market www.facebook.com/VacaMooAirport/
Old 09-11-2023, 04:54 PM
Tall_Order's Avatar
Tall_Order Tall_Order is offline
Default I am experimenting with the BRS/WARPS idea
Granted, a chute pack would weigh more than a battery, but do not a lot of RV-8s opt for a rear mounted battery to bring C of G aft? Could not a fwd battery (with that mass now at an inverse arm) and a specific engine/prop combo make the rear seat usable at all?
I am modifying a RV-7 BRS kit for a RV-8A Fastback(Turtledeck remains clear and fuselage height for aft straps is similar) but there is a ways to go on this install. If you have info about of a flying RV-8 with this system, please post!
ID:	47812  Click image for larger version
RV-8A Fastback
Fuselage SB about 2/3 done, pre-close inspection complete, Fastback mod complete, working on electrical/avionics
Wings SB haven't started yet... (LCP hold)
Empennage Inspected, closed
Donated 2022
Old 09-11-2023, 06:09 PM
warmi warmi is offline
It is unfortunate that BRS ( or GRS or Magnum ) is not a standard option as it is for instance on Zenith planes.
These things do save lives … like this guy here , had it not been for BRS he would have been 100% dead ( much easier to pull a handle than try to bail yourself out )
https://youtube.com/watch?v=4a8cntPd...z0Ztazsz0h4cI4
Old 09-11-2023, 11:16 PM
N546RV's Avatar
N546RV N546RV is offline
Yeah, I'm surprised to hear that about a rear-seat passenger. My impression has always been that the -8s tend to have issues with the CG being too far forward when solo. There are a couple threads floating around with people talking about ways to put easily-removable ballast back in the tail to make the plane fly better solo.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 09-12-2023, 06:57 AM
PhatRV PhatRV is offline
When I did the W&B for my RV8, it was near the rear CG datum at 1800# with full fuel and a big passenger, and full weight in the rear baggage compartment. As the fuel gets to minimum, the CG shifted past the rear datum by a few percent.
I have the light weight fixed pitch composite prop. But I think having a heavier constant speed prop will get a better balance at gross weight. There was a story posted here about a RV8 with passenger returning from Reno Air Race and the pilot experienced PIO when landing with a light fuel weight.
RV8 (N38PV)
Days to First Flight: 999
Old 09-12-2023, 06:59 AM
DanH's Avatar
DanH DanH is offline
I've worked with several BRS and Second Chantz installs on light stuff. One aspect seldom considered is decapitation.
Given an airframe failure, there is no way to predict the attitude of the fuselage at deployment. Watch old BRS movies and you'll often see tumbling balls of junk. So, it's really helpful to have some structure around the cockpit in order to keep the bridle straps away from the pilot. If the canopy opens while a bridle is across the torso or neck...
Something like a Cirrus has an enclosed cockpit, here notable for its roof structure to keep the straps out.
Related, designers often try to arrange the rocket system so it fires aft and up and hangs upright. That's terrific if the assumed reason for deployment is an engine failure with the airframe gliding straight and level. It's entirely appropriate for a family airplane with a power failure in a bad place, and it sells well in the pictures. However, given an aerobatic airframe failure, it doesn't matter if the deployment is out the side or through the belly, because there is no way to predict "up". The only high probability is shooting more or less rearward, as even the balls of junk eventually tend to assume heavy end down.
Bottom line, you may want to re-think the 4-strap suspension, as it pulls the forward straps across the cockpit if there is any activity in the roll axis. Even if the strap does not reach the meat servo, a canopy collapse won't be pretty. A system with two aft straps doesn't guarantee no cockpit involvement, but it a lot less likely.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-19-2023, 01:30 PM
pv9 pv9 is offline
Have you successfully installed either BRS, Galaxy or Second Chantz on a RV-8? BRS routes the straps entirely outside the cabin on the 7 and 9 but they don’t have a system for the 8.
BRS told me this morning that they started an RV-8 project years ago and gave up. The person could not tell me why.
Donated Feb 2022.
Old 09-20-2023, 06:16 AM
I am completing the installation of the parachute on my plane; these drawings I have attached are from the engineering project for the equipment installation. Once it's finished, I'll send it to you.
