Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-13-2023, 11:15 AM
Difference between RV8 and RV8-A ?
Hi,
Brand new here,
What is the difference between the RV8 and the RV8-A ?
09-13-2023, 11:21 AM
Nosegear v. tailwheel
Welcome aboard! The -A designation indicates a nosewheel RV. No "A," it's a taildragger.
Originally Posted by Acat
Hi,
Brand new here,
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2023 Dues Paid
The 8 is a tailwheel design, and the 8A has a nose wheel instead. Performance for both is the same. Opinions on sex appeal will differ
Paid up - Sep 2022
09-13-2023, 11:24 AM
That sure can’t be… just bravely sitting on the ground one is already faster than the other
09-13-2023, 12:27 PM
Odd one
But, for completeness, the RV-10 is the exception to the rule. No ‘A’ but it has a nose wheel. Little confusion as Vans doesn’t sell a 10 in a tail wheel version.
09-13-2023, 02:13 PM
For a little more detail, the 8A will be a little bit lighter for the same engine and panel, you have a bit more foot/leg room in the front (width) because the "gear towers" aren't there. The -8 is probably a little bit better at rough unpaved fields but neither is a hard core STOL machine.
Most (including me) think the -8 looks better on the ground, but in the 8A you can see better when taxing. Nose wheel usually means cheaper insurance.
Both should look/feel the same from inside while in the air.
09-13-2023, 02:20 PM
Moderator, Asst. Line Boy
And the RV-12. Only comes in a nose-gear configuration, no taildragger.
Scroll
VAF Moderator
FFI Check Pilot
Exemption waived.
Proud and grateful 2023 -=VAF=- Contributor
09-13-2023, 02:44 PM
And don't forget, the RV-9 started out that way! Very early RV-9s were tricycle gear without the "A".
Mel Asberry, DAR since the last century. Over 1,100 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
09-13-2023, 03:05 PM
Good summary from Van's of the RV-8 and RV-8A, with links to Aircraft Specs and Performance Details of each variant:
https://www.vansaircraft.com/rv-8/
Carl N.
RV-8
KAWO
Thread Tools |
Display Modes |
