Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
02-01-2021, 12:44 PM
Senior Curmudgeon
RV 10 build tips and gotchas
Starting a thread as a common source for RV 10 hints.
Folks, feel free to add either a link to one of the prior threads, or just add your tip or watch out.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-01-2021, 12:50 PM
Senior Curmudgeon
Check list sample
Mike Starkey
VAF 909
Rv-10, N210LM.
02-01-2021, 12:53 PM
Senior Curmudgeon
Door gap tip
Mike Starkey
VAF 909
Rv-10, N210LM.
02-03-2021, 11:14 PM
Rudder cables
Don’t install the snap bushings in the guides for the rudder cables until you slide them over the rudder cable.
02-04-2021, 12:24 PM
Senior Curmudgeon
Door struts
Mike Starkey
VAF 909
Rv-10, N210LM.
11-07-2021, 07:22 PM
HS Inspar Rivet to Front Spar Installation
The 8 rivets fastening the center HS-905 nose ribs to the front spar to the HS-1004 inboard inspar ribs were a nightmare for us. We recommend using a really long rivet set on them. If you are like us, we had no clue the long set would require the gunner to push VERY hard to prevent damaging the heads. PRACTICE with the long set first!
Best of luck!
Mike
DUES REMINDER: JAN 2023
RV-10
Tailcone 90%, Wings 25%
Fuse, Finish, FWF, Prop Onsite, Engine Dec 23?
11-08-2021, 08:10 AM
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
11-04-2022, 11:11 AM
F1032 L R longerons
I just wanted to share with the community when creating the left and right longerons (F1032L and F1032R) for tailcone make sure you create mirrored parts. I accidently drilled the 1/4" holes on same side. This created 2 left 1032:-( See picture attached.
This made me have to buy another 98.5" piece of AA:-(
Thread Tools |
Display Modes |
