Old 11-18-2021, 10:58 AM
rk2436 rk2436 is offline
Why bother losing 5 kts and $4200 ? Photoshop a 3 blade on your -12 if want to send a picture looking cool. Makes me want to switch over my 2 blade Sensenich to my Rans S21 to see if I can improve the performance.
Old 11-18-2021, 01:34 PM
cactusman's Avatar
cactusman cactusman is offline
I think it was more than looks and performance. With Van's incorporating basically an annual dynamic prop balance, dealing with that protractor, the different weights of those sensenich blades etc.
When you compare the 3-blade Sensinich pricing and all the parts and spinner from Vans it probably isn't that far apart. Of course the ELSA certification for builders ordering kits adds a wrinkle, so Vans really needs to offer this as an option imho.
John
RV12 Built and Flying
RV10 Started
Old 11-18-2021, 02:52 PM
seagull seagull is online now
Does anyone have a weight comparison?
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 11-18-2021, 05:44 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Suppose you operate at higher elevations (Denver) and want more pitch? Seems like ground adjust would be answer as opposed to a "fixed" fixed pitch prop...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old Yesterday, 07:25 PM
georgedouglas georgedouglas is offline
I finally got my Catto prop installed on my RV9A 0-320 160 HP Lycoming. Besides looking cool, it does everything Catto claims. I can only get 2500 RPM so far at 3 to 5,000 ft altitudes WOT. My static RPM is 2180, which is a bit low. With the Sensenich prop I could easily get 2600 RPM and static was 2250. So that's the only issue so far. The prop really works good as a brake when in the pattern, which is what I need for my grass strip that has rising terrain at both ends.
george
RV9A
2TN7 Wolfcreek
President EAA Chapter 17
Knoxville TN
A&P & Private Pilot
USAF 1966-1970
1970-2001 DAL
www.oilhelp.com
