Old 11-11-2021, 05:28 PM
seagull seagull is offline
Default USB port (resettable)?
Today when I rolled out to take off I plugged in my phone to the USB port to charge and it would not charge. During the flight of 20 minutes I checked the fuses and tried another phone, no joy. I landed had breakfast and flew home, again checking the USB port on warm up and now it is working. I have never had a problem with it before. Any ideas?
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 11-11-2021, 07:30 PM
Slightlyabnormal Slightlyabnormal is offline
If its a USB port connected to your electronics, it probably did shut off and reset.
Spec for USB-A is only 500mah, many devices disable the port if that is exceeded to prevent damage.
Id recommend a USB adapter for your auxiliary power port, it will provide more power safely and charge your devices quicker. Look for one QC or PD (fast charge protocols).
Old 11-11-2021, 08:30 PM
jliltd's Avatar
jliltd jliltd is offline
What kind of port (i.e. make and model) and panel mounted or adapter?
Jim Ivey
RV-8
(and a few more airplanes)
Old 11-12-2021, 06:51 AM
BillL BillL is offline
Commitlift.com And while there read his presentation on Apple USB programming.
If you are not using Apple - ignore this.
Bill
RV-7
Old 11-12-2021, 09:27 AM
BoydBirchler BoydBirchler is offline
It has been my experience that the charging cables become intermittent at times. Some times on my Ipad/ Iphone, when it fails to charge, I can turn the connector 180 degrees, slide it back in the phone, and it will charge.
My experience: I have a large collection of failed cables, but only a few failed chargers...
Old 11-12-2021, 04:45 PM
rondawes's Avatar
rondawes rondawes is offline
Over the years, I've had intermittent charging on my iPhones from time to time and each time, I got a wooden toothpick and gently cleaned out the lint and dust from the lightning port and then the cable that would not charge worked worked fine. The lint prevents the cable from seating in the port fully.
RV-7A N625TD
Based KTKI
Donation paid June 2021
Old 11-12-2021, 05:48 PM
The port was aftermarket and between the seats on the front of the pedestal.
I will need to research the mfg, maybe it is self re-settable.
The problem was not lint although I am aware of that issue. I had tried 2 different phones and an Ipad, none worked but all worked on the next flight.
-- Walt --
Old 11-12-2021, 07:10 PM
sailvi767 sailvi767 is offline
Same charge cord with all those devices? The classic cord failure I have had often is it fails to charge then works. Over time it gets worse until I toss the cord. New one solves the problem. Many aftermarket cords have a very short life.
RV-6 sold
F-1 Rocket
Old 11-12-2021, 09:11 PM
Two different cords were tried, and flipped, and neither worked but both worked on the next flight.
-- Walt --
