Keep VAF
Going
10-29-2011, 10:29 AM
What is this tubing?
I've seen a few builders with this clear, perhaps 1/4" tubing they have run to under the baggage floor. In this picture for instance ( https://s3.amazonaws.com/expercraft/...0cc7c6e391.jpg) but Tim Olsen also has one. What is this? Did I miss something or are people just using a clear conduit for wiring runs?
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
10-29-2011, 10:37 AM
Pitot static maybe?
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
10-29-2011, 10:39 AM
this is the tubing for the static ports which are located in the tail cone and must be run up the the pannel. Most of us use clear plastic tubing for the static lines
Eric
N410EG - flying
Eric Gohr
40271
N410EG
10-29-2011, 10:40 AM
It looked a little thick for static tubing, I read a little farther and I think it was being used to route coax for antennas to the seat area.
RV-10
N928MT
Build Project Site
10-29-2011, 11:20 AM
Tim used 3/8 inch conduit for his antennas, I dont know what he used but I found 3/8 conduit at Harbor Freight, its black and corrigated but it will work great.
Steve Stella
#40654 Finishing
N521RV reserved
10-29-2011, 11:50 AM
It is flexible wiring conduit
Tim Olsen used 1" flex computer conduit to run wiring through the fuselage from the rear area (where the batteries are) to the panel. It is very lightweight, heat resistant and, most importantly, wont give off noxious gases if it were to burn or melt like regular plastic tubing will. It is costly if you have to buy it but I found some being thrown away after a computer center rehab so I did the same as Tim did in my -10.
Roger Pierce
Broken Arrow, OK
RV-10 40148
Reason: Forgot signature
10-29-2011, 04:05 PM
Actually, I'm not referring to the orange tubing used for wiring conduit. If you look at the picture, there is a clear ~1/4" tubing on the rib closer to the person taking the photo. The Orange conduit is farther away.
RV-10
N928MT
Build Project Site
10-30-2011, 05:29 AM
I see it now... I didn't see it before though. Don't know about that one but I suspect it is the static line as mentioned by others. I guess I'd better pay attention before I open my yap next time!
Roger Pierce
Broken Arrow, OK
10-30-2011, 10:06 AM
The clear line is 3/8
Steve Stella
#40654 Finishing
N521RV reserved
10-30-2011, 11:50 AM
I used that clear tubing as a conduit for my strobe wires, and also used the same for going under the rear seats for my antenna wires. It was just a simple way to go so that I could install the wiring later, without having to have access to those areas. I wasn't ready to install any electronics at the time, so I gave myself a way to run the wires later.
Tim
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
