Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-10-2023, 09:52 AM
SEM
Buy a case of SEM rattle can.
Some parts should be primed. The manual will tell you.
It's a perfectly good etch primer.
The other stuff, it's your plane. At the very least, a wipe with Isopropyl or Denatured Alcohol to remove contaminants.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2023, plus a little extra.
RV-7A #73391, N511RV Registered
Disclaimer
09-10-2023, 10:11 AM
doug reeves: unfluencer
Your profile shows Nevada?
NO PRIME - NO WORRIES. <g>. It'll outlast you for sure!
v/r,dr
Originally Posted by YME
After talking with different contributors on this forum, reviewing pros and cons of primed parts, and my local EAA Chapter input, I have decided to the unprimed assembly. As I live in Southern Nevada myself and others foresee no problems.
Now question is, do I wipe down all the parts with a cleaner (acetone, etc) after deburring where and when necessary and removing the blue film protector.
Doug Reeves RV-6 (your host) - FT: VansAirForce.net since 2007 (started it in 1996).
- PT: Contract pilot. SIC in any plane that will have me. ATP. PIC typed in Phenom 300 and G-V(450/550). Flying resume.
- PT: CAE Phenom 300 sim seat support @ KDFW. 435+ sessions.
09-10-2023, 11:58 AM
Could buy an Alodine pen or maybe I am again over thinking.
Probably
Properly executed trimming on any skins should result in the same edge condition as all of the skins have, so if it is justified for that, it should be done on every skin.
If used carefully and waste is minimized, one can of Sem primer (two at the most) would be enough to prime all of the parts specified on an RV-12.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR & Pre-purchase inspection Services
A&P, EAA Technical Councelor
09-10-2023, 01:11 PM
VAF #897 Warren Moretti
2023 =VAF= Dues PAID
09-10-2023, 02:50 PM
SEM
Only reason I say buy a case is because that one can always runs out at the worst possible time.
Plus, once you like a primer, you tend to find other uses for it.
Probably cheaper by the case too.
Larry Larson
Estes Park, CO
Disclaimer
09-10-2023, 04:30 PM
Per Van's instruction no primer needed except on extruded and non CLAD Aluminum parts.
Where ever steel attaches (even if steel is primed and painted), I etch, anodyne, prime the aluminum locally at the interface.
You can wipe it down with what ever you want, alcohol might be my choice and less aggressive than Acetone thinner.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2023 Donation Made!
09-10-2023, 05:19 PM
no prime
Only primed dissimilar metals. The attached photo is this year and show 11 years of time and still looks good.
09-14-2023, 10:05 AM
I bought a bottle of Corrosion X and wiped a very very thin film on mating surfaces and where I deburred / sanded parts. This gives some protection without making a mess. Be careful to not apply too much. If corrosion X weeps out on to the exterior, it will make painting later more difficult.
09-14-2023, 11:34 AM
Back in the day, The big 3 only primed interior parts if you coughed up extra cash when you wrote the deposit check, or if you ordered seaplane provisions.
There are jillions of 50 year old airplanes out there that still look like new inside all the unpainted nooks and crannies.
Having said that, I've seen a few that were absolutely turning to dust due to living their life in a salt air environment.
If I lived in Nevada or Arizona I wouldn't waste a minute considering it.
09-16-2023, 03:17 PM
"CorrosionX"
Clean the parts. Once fully assembled AND painted, spray the non painted area with "CorrosionX". It will protect it and weep into all the nooks and crannies. Every annual wipe the areas with a cloth and reapply "CorrosionX" with a cloth.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
