w/a Donation
VAF on Twitter:
@VansAirForceNet
  #71
Old 06-24-2023, 06:07 PM
Brantel's Avatar
Brantel Brantel is offline
Default Double Face Palm
Well I punted in the wings till
My new right spar shows up (factory rework defect that engineering said was a no go).
Started working on the fuse and almost immediately ran into an issue.
These two holes were incorrectly dimpled at the factory and are supposed to be left at #30 and drilled by the builder to #12 for bolts.
Anyone else run into this?
Click image for larger version
ID:	44379  Click image for larger version
ID:	44380  Click image for larger version
Brantel (Brian Chesteen),
RV-12IS Empennage/Tail Cone Finished, Wings and Fuselage Kits In Progress, Finish kit on order!
Serial #121606, N912BC (reserved)
Check out my RV-12IS builder's BLOG
Check out my RV-10 builder's BLOG (Good stuff for those starting an RV-10)
RV-7/TU, #72823, N159SB Airplane Sold
Old 06-24-2023, 07:48 PM
EchoJuliet EchoJuliet is offline
Yep, I had the same question back in 2018. They said that when enlarging the holes it would clean up 98% of the dimple, but that's not actually true. Here is the response from Vans.:
I agree it would make more sense to not dimple these but they have always been dimpled during the prep of these parts. I will pass this along and see if I can get them to reconsider this.
Old 06-24-2023, 09:13 PM
rv9builder rv9builder is offline
Yes, my center section has those same two holes dimpled.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2023
Old 06-24-2023, 09:25 PM
Brantel's Avatar
You get any guidance from Vans?
Old 06-24-2023, 09:50 PM
UNCRV UNCRV is offline
It’s been a year or more since I did this but I’m pretty sure I drilled them to #12 and continued building.
Old 06-25-2023, 12:13 AM
No, but I didn't ask. I figured I'd just drill to #12 and, if necessary, find a way to flatten the dimples. I haven't bolted the F-1204R retainer block to the center section yet (Page 21iS/U-11), so I don't know if it will be necessary to flatten what's left of the dimples.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 06-26-2023, 12:50 PM
Brantel's Avatar
So based on the replies that Van's has directed others to drill out the dimples to #12 and build on, I decided to smash them flat and drill em. There is still a small bit of the dimple remaining but it should be a non issue with the bolt/washer/nut that holds the spar alignment block.
Seems the reports of this issue go way back. Its a shame that they continue to make these parts incorrectly.
ID:	44479  Click image for larger version
ID:	44480  Click image for larger version
Old 06-26-2023, 06:52 PM
Brantel's Avatar
Anyone know what these extra holes are for in the main center section assembly?
They are right above the ones that get countersunk.
ID:	44500  Click image for larger version
Old 06-27-2023, 01:21 PM
That doesn't look right. They were definitely not there on my kit. I think a call to Van's is in order.
Old 06-27-2023, 01:33 PM
Here's a photo of mine.
