w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 01-20-2021, 09:00 AM
bobg56 bobg56 is offline
Default Inner Tubes
My nose tire went flat so I'm shopping around for 3 since they are all 10 years old now so I might as well replace them all, Tire's are Areo Classic 5.00-5...looking at Spruce a 5x5 tire tube is $72.75 each, the tube that's in it is a "Leak Guard" with is about $25.00 but it's not a 5x5 size...anyone know of a cheaper alternative to paying $72.75 for a tube?
Old 01-20-2021, 09:34 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
About ten years ago my wife and I were grocery shopping and discovered that butter was exorbitantly priced. My wife asked the store manager why the recent price escalation? The answer they gave her was an El Niño caused a disruption with cows producing milk from which butter is made.
So, my answer to you is… It costs what it costs. Tires and tubes have been increasing in price.
It’s like the airlines – they own (or lease) the planes and if you want to fly you buy a ticket.
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 900
Old 01-20-2021, 10:05 AM
12vaitor 12vaitor is offline
You could buy them from the Van's Store for $59 each.
https://shop.vansaircraft.com/cgi-bi...duct=tire-tube
John Salak
RV-12 N896HS
Old 01-20-2021, 10:13 AM
Ironflight's Avatar
VAF Moderator / Line Boy
If you’re only going to replace your tubes every ten years, then maybe think about putting in the best - the Michelin Air Stops. You’ll probably only have to add air once every six to eight months, so you’re more likely to keep them at a good pressure. And yeah - they’re expensive!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-20-2021, 11:06 AM
Thanks for the reply's, $59 is better than $73...I will order from Van's...
Old 01-20-2021, 11:11 AM
NinerBikes NinerBikes is offline
You're taking a trip to the moon... would you want the rocket ship built by the lowest bidder, when your life depends on it?
It's something I think about with tires and tubes. If you have to pull wheel pants every time you want to check the air pressure in your tires, a good leak free set of tubes is worth the extra money, vs monkeying with those screws on you back all the time down there.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 01-20-2021, 11:12 AM
BH1166's Avatar
BH1166 BH1166 is offline
Default Shipping
Cost are going to run up the price....one corner USA to the opposite. Pricey getting stuff from VANS to Georgia, takes a week or more too. YMMV.
Butch
RV6A Purchased N72TX
Old 05-02-2022, 08:33 AM
Piper J3's Avatar
Default Tire Sealant....
I recently converted a ten-year old Trek bicycle to e-Bike. The tires and tubes needed replacement for fear of getting a flat tire on the road. I did some searching and discovered that a lot of folks are using a liquid sealant in the innertube to self-seal punctures. The sealant also slows air egress and tires retain pressure longer. The sealant used is Stan's NoTubes Tire Sealant... 2oz is used for a single bicycle tire. The sealant looks like watered-down Elmer’s white glue.
So, my question is…. Is anybody using a sealant in airplane tires?
Old 05-02-2022, 10:03 AM
funflying funflying is offline
I haven’t done it myself but I know others who used the green slim know as Fit-a-flat under the same premise of preventive measures for their tubes.
As I recall as time of use went on other’s experienced an out of balance feel even with the stuff remaining liquidity inside the tube. The original thought was as the tire spun the stuff would disperse and this worked okay on takeoff but on landing, going from 0-65 (RV6) didn’t happen so smoothly. Anyway you get it.
This is my only knowledge of someone else’s sealant prevention and as far as preventing loss of air over time or puncture I don’t think it was worth the effort using Fix-a-flat.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 05-02-2022, 10:52 AM
I've used Stan's in my 29" Mtn bike tires with tubeless settups and it stops leaks quickly, with items like goatshead thorns and such. It does NOT work well in tubes at all, otherwise Stan's would sell prefilled innertubes with Stan's sealant in them.
Slime works well both in tubes and in tubeless applications. Slime does sell prefilled tubes with their sealant in it.
The problem is that it works fine from a rolling dead start going up to speed, but it will definitely create an imbalance in the tires the moment you touch down and your rotational speed of tires goes to 200 or 300 rpm or what ever the speed is when your tires touch down. It's going to be violent, with that imbalance.
Get the good Michelin tubes, is my suggestion.
VAF dues paid 2022
RV-12, KWHP based
