Yet Another Figure 8 Dimple.
berck
Member
Yesterday, I damaged a hole while dimpling the F1073-L side skin.
Outside:
Inside:
I read through many of the figure 8 fixes here, but none of them were quite as bad as mine. The original hole location dimple was cracked, which meant I couldn't just put the rivet in the hole and add some epoxy when I put it all together. I wrote Van's, but instead of losing an entire day of working on the airplane, I decided to file it out until the cracks were gone, then drill the hole out to #19 (which was close to round, but still not quite), dimple it for a #8 screw and install a nutplate on the F1010. This turns out to have been a terrible decision. The dimpling for a #8 screw caused further cracks, and seems to have enlarged the hole as well. It's now roughly 3/16", and has cracks:
At this point, I see only 3 options:
(1) Buy a new skin. This is what I'm planning to do, absent advice to the contrary.
(2) Fabricate a patch for the skin. Given that from what I've read in my copy of Aircraft Structural Technician, I'd need a huge patch (something big enough for a dozen or so rivets). I'd also have to have the patch match the curve in the skin, which I think would be very difficult. Also very, very ugly. I'm not looking to build a show-quality plane, but a giant patch resulting from a simple mistake with the dimpler is just not very appealing. I'd rather spend the money on the new skin, which I'm sure will be a rather large pile of money. A patch seems like a good option if I'd already built the plane, but at this point I can buy a new 1073 and be as good as new.
(3) Leave out this rivet entirely. Drill out with a unibit until the cracks are gone, fill with epoxy and hope for the best. I'm only willing to do this if someone at Van's thinks this is an acceptable option. It seems like a bad idea to me, but I'm no aeronautical engineer. Note that I cannot add a rivet to either side of the botched one, as this is in a tab on the curve of the F-1010 and doing so will take me way too close to the edge of the tab.
Maybe I'm missing another option. Any advice appreciated.
Berck
Bad dimple
Ask Vans first but one solution is another hole on either side with the correct spacing. Fix the bad hole by drilling as you mention but leave it empty for future filling.
Mind if I ask why you scuff the rivet line outside?
I think that would be cutting it awfully close? The F1010 tab with a single hole in it is 1". 3/32 rivets need 3/16" spacing. Edge to first rivet is 3/16. +3/32 for the rivet. +3/16 spacing to the original rivet... Leaves me 1/32" too short, not accounting for the fact that the skin hole is 3/16" now. If I want 3/16" spacing from the skin hole... that leaves 1/8" edge distance to the edge of the tab. Maybe if I split the difference?
I haven't found a deburring tool that doesn't remove what I consider to be a lot of aluminum. I'm okay with using the tools on thicker material, but on skins I worry that the chamfered holes after deburring are too thin. So I deburr holes in the skins with scotchbrite, because I know that won't remove any real amount of material. I figure the paint shop is going to rough it up way worse than that, anyway. (That's my reasoning... but I'm certainly not going to claim I'm doing it the RIGHT way.)
Hope you find an easy solution for that hole.
A bit of drift but relevant.
I dimpled most everything upside down. Having the dimple die with the mandrel on the bottom and the female die on top allows you to visually ensure the dies are in the right place before setting the dimple.
This works very well in a C frame dimpler and enabled me to dimple at about
1 dimple every 2 seconds. Most of the time was taken up to reposition the work piece.
On the bright side you have a lot of company with holes like that:)
Amusingly, this is exactly what I did with the DRDT in the problem hole. For big sheets like this, I usually dimple with the male end on top to avoid the scratches on the bottom side. But, I wasn't thrilled with the first hole I did on the curve like this (scratches and dents on the curve), so I swapped the dies and did it like you're suggesting. The mandrel was sticking through the hole when I pulled the lever. Unfortunately, rather than slightly straightening out the curve to make the dimple, it pulled the material sideways, cracking/destroying/figure-eighting the hole. I wish I knew what I did wrong. I did the rest of the holes (and the other skin) with the male die on top and it worked fine.
Yes, I absolutely should have used that pop rivet tool. I completely forgot about it. I had a few of them, but I think I managed to "pop" most of them, while barely making a dimple in the stronger material. Perhaps the version I had was not-so-good. I'll definitely get more...
I found that using a smaller diameter die worked much better on the curves. The set of dies that I got when I purchased my used DRDT included a normal sized one and a 3/8" diameter one. The smaller one worked great...
patch
I would go to a #8 screw in that hole. Match a patch for the inside that will span out into the skin in front of the hole. Put a couple of rivets that will tie the skin to the bulkhead. You will have to put a slight joggle in the patch and bend it match the radius of the fuse bottom so it can go up and over the bulkhead flange. Once you are done you can put some JB weld around the area that got creased. Yes, you will see the screw, but your not throwing away an expensive skin. The patch will lap over the bulkhead flange and it will have a #19 hole drilled into it. The rivets holding the patch on the skin will take some of the load off the enlarged holes in the skin. Had to do something very similar when we had an RV-3 propted up on sawhorses in the flying position. We were putting on wing tanks and pushing on the tank when the sawhorses holding the tail rocked back and the tail cone came down and crease the underside of the fuse. Put patches in those areas and bondo to conceal. Been flying around for 20 years plus now......
I haven't found a deburring tool that doesn't remove what I consider to be a lot of aluminum. [/QUOTE said:
I use a small 100 degree countersink from Avery or Brown, chucked in a battery powered screwdriver, works great, and quickly, as a deburring tool, and it's very easy to precisely control the amount of metal removed. Tried countersinking cutters, and, like you, found that it is easy to cut too much too quickly.
I would recommend the #6 or #8 screw and a nut as well, but without the extra stuff. Fill he hole with a screw and build on. It's one hole. Fill it with some filler before paint and it will disappear.
Thanks so much for all the suggestions. In the end, Van's support recommend that I drill extra rivet holes on either side, and just cheat the distances. I think the result is probably just fine, and hopefully with some filler and paint no one will be able to notice. The two small holes are to stop drill the cracks that formed when I tried to dimple for the #8 screw.
