Old 11-24-2020, 06:49 PM
MartinPred's Avatar
MartinPred MartinPred is offline
Default Separate Mag Switches
I forgot to mention that I don't use a key switch. I have separate toggle switches for the left of right mags, with the starter on the stick. This allows me to keep good control of the stick and throttle when starting.
So I can't see how it's a bad switch. But I suppose the hot P-lead trick is worth a shot.
The full ground check looks something like this:
Both on - smooth engine running.
Left off, Right on - ~100 rpm drop
Left on, right off - no change
Left off, right off - engine dies
right off, left off - engine dies
Impulse coupling is on the left mag. I always start with the left on, right off.
I'll grab my local A&P buddy to help me double check the mag timing. I'm using a standard timing light and both the red and green lights with the tone come on and off at the same time through full rotation. I'll also double check the timing stripe. Maybe I have the right one 180 degrees off?
-Matt
Old 11-24-2020, 07:47 PM
Taltruda Taltruda is offline
-Matt
Bingo. .you can't time mags going through a full rotation. . The left mag needs to snap the impulse coupling, then you back up the prop a few degrees, and go forward again (to get the gear slack out) timing the mag after the impulse coupling.
Tom
Las Vegas
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 11-24-2020, 08:29 PM
Flying8 Flying8 is offline
Darn! Yeah separate switches makes it a little more difficult. I was hoping it was a simple key switch.
Jordan
RV-8 tail complete 11/3/20
Standard fuselage in-work 1/7/21
RV-6 N926DG: Purchased & Sold
A&P, Comm. SEL/Rotortrash
Old 11-24-2020, 09:49 PM
gasman gasman is offline
Yep! I also expect left mag NOT timed properly.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 11-25-2020, 06:12 AM
MartinPred's Avatar
Default Timing
Wow. Ok. I will give that a try.
-Matt
Old 11-25-2020, 09:33 PM
MartinPred's Avatar
Default All in the Timing
Yep. That was it. Turns out I had the impulse coupling timed to 25 degrees before TDC. Which means the left mag was actually 50 degrees before TDC (!). Itís amazing it ran at all!
Did an engine run and a test flight with the correct timing set. Itís like a new plane! High CHTs on the right side disappeared. And tons of power.
Thanks everyone for the help!
-Matt
N402BD
Old 11-26-2020, 02:00 AM
rv8ch's Avatar
rv8ch rv8ch is offline
-Matt
N402BD
Matt, thanks for closing the loop on this one. I can guess that the first spark came in so early it didn't have a chance to burn much of the fuel/air mixture before it was compressed, but will leave a good explanation to more experienced folks.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-26-2020, 07:09 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default I feel bad....
Us dual mag folks probably should have seen this one. We let the impulse release before working the prop Backwards to check timing...glad you solved it. I admit to having the same issue...and can tell you the Lyc will run with HUGE advance at low rpm, pretty well, thank you.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
