Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 10-19-2021, 11:12 AM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
All your planning questions that everyone else has mulled over on the RV 14 forum are consolidated onto the "General construction" and "Avionics" PDF's on the WIKI (see signature)
Enjoy
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB stuck in China virus corrosion purgatory
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
please purchase the thumb drive Vans offers. I DO NOT want to take away from sales flow or get the WIKI Killed.
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
Old 10-19-2021, 06:27 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Originally Posted by ryane67 View Post
Since my -14 will be a taildragger I ended up getting the "original" kit for the wingtips, the tail light kit model, and then two of the Leading Edge/Taxi Light combo lights for the pre-cut holes in the 14 wings.
Hi Dennis
Ryan has chosen the recommended Flyleds setup for an RV-14. Perfect!
The regular tail light flashes in sync/pattern with the wingtips and is what most of our customers choose.
If you're building a nose wheeler you can choose our Quad Spots instead of the Combos. Or, for the best lights ever our Seven Stars will be right at home in the leading edges.
Note that the price of Van's tail light alone is almost the same as our complete strobe system...
I don't plan on making any major changes to our products at this point, but others are correct in that you don't need to purchase a tail light or the rest of the system just yet. However I'm always here for you whenever you'd like to spend some money!
Paul McVitty
Flyleds.com
VAF advertiser
Old 10-20-2021, 05:27 PM
didja didja is offline
As most everyone is suggesting, I would also agree not to purchase the light with the kit and wait to see what else is out there. I ended up going with FlyLeds and purchased their Seven stars wingtip lights and tail strobe setup. I only had to slightly modify the installation of the wing leading edge lights by turning them about 45 degrees or so if I remember correctly to mount to the Van's provided mounting plate.
They are extremely easy to build and as Paul stated, the price is unbeatable for an outstanding product with outstanding customer service.
good luck in your build! its a fun ride!
Scott Emerson
RV-14a Kit# 140432
Working on: Fuselage
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
Old 10-20-2021, 11:30 PM
acpilot's Avatar
acpilot acpilot is offline
Paul
Thank you for the info. After reading the responses from others and yourself I will be going with Flyleds. I noticed that you are based in MEL. When the borders open up and international flights I'm sure I will be back doing layovers in MEL at the Crown in the CBD. Perhaps I could stop by, discuss the best option for my build and purchase a kit.
Dennis
Flown:
C-185, DHC-6, CT-114, CC-130, A320, B767, B787
Ready to start flying for fun.
RV 14A Kit #141156
RV 14A Empennage Kit Ordered (ETA Mar 22)
C-FDBX (Reserved)
https://eaabuilderslog.org/?s=acpilot-RV14A
Langley B.C Canada
2022 Dues Gladly Paid
Old 10-20-2021, 11:34 PM
acpilot's Avatar
Scott
I watched your video on the assembly of your Flyleds kit and it convinced me they are the right choice. I was a bit intimidated until I saw your video. Thank you for being such an informative source online.
Dennis
Flown:
RV 14A Kit #141156
C-FDBX (Reserved)
Langley B.C Canada
Old 10-21-2021, 01:21 AM
Originally Posted by acpilot View Post
Paul
Having been in lock down here for so long here in Melbourne, what you're describing, ie meeting a visitor from another country again, is beyond my wildest imagination!
For sure, but only if I can buy the beers.
Paul McVitty
Flyleds.com
VAF advertiser
