Staunch111
For those who have installed outboard tanks, with aux pumps (as a back up)to assist fuel transfer into the mains - which fuel pump did you decide on. I'm looking at the Facet pump that Vans sell (ES 40108) "12v solid state fuel pump for all RV models (except RV-12). 3/8" male outlet ports with 37 degree aircraft fittings. Provides 6 psi. NOT for use with high pressure (fuel injection) systems" which is now unavailable. Any advice on alternative pumps?
