Old 05-22-2019, 01:15 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default Problem with D180 Fuel Display...
I have dual screen Dynon D180 and D100 in my RV-12. I just recently recalibrated my fuel quantity gage per Dynon instructions. Now I notice that I no longer get a yellow box around the digital number of gallons remaining at 7, nor do I get a red box (steady or blinking) around the digital number of gallons remaining at 3.5. This used to work fine and I would also get warning on bottom of screen which needed acknowledgement.
I have contacted Dynon and they tell me that the unit they have on bench does exact same thing. They were a little surprised and don't have a solution.
Anybody else having this problem?
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 790
Old 05-22-2019, 01:39 PM
DennisRhodes DennisRhodes is offline
Maybe change that 7 and 3.5 to something else,now that you have re calibrated sensor, then you can move both back to 7 and 3.5 . Thinking that the re calibration may have voided those original limits for red and yellow. Just a shot in the dark
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 05-22-2019, 02:54 PM
Harvey rv12 Harvey rv12 is offline
Probably unrelated, but do you have 2 fuel pressure readings?
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 05-22-2019, 03:06 PM
Piper J3's Avatar
I'm not following your question. The screen shot in my first post is the EMS screen and I guess it shows fuel pressure in two locations. Fuel quantity is also shown in two locations on the same screen.
Old 05-22-2019, 04:01 PM
I thought if during your recalibrating of your fuel level, perhaps you erred in some way, ie 2 indications of fuel pressure, one beneath the oil temp indicator, and one in the lower right of screen.
Tom O.
Hoskins Field, 44T
Olympia WA
price is forgotten.
Old 05-23-2019, 08:14 AM
airguy's Avatar
airguy airguy is online now
Having worked with Dynon for a while as a beta-tester, I can tell you that if (A) their on-the-bench unit did the same thing, and (B) it was a thing that it shouldn't be doing, AND (C) they couldn't tell you what to do next, then they are certainly digging into the software code behind it and will have an answer shortly.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Old 05-23-2019, 10:03 AM
Piper J3's Avatar
I hope so... I'm afraid there is limited support for the legacy equipment.
Just strange that all the other warnings are working - oil press, temps, but not low fuel quantity.
Old 05-28-2019, 11:33 AM
Piper J3's Avatar
I contacted Dynon about my D-180 fuel gage problem (see post #1 above) and they tell me none of the software engineers who designed the D-180 are working at Dynon on anymore. Dynon also tells me they have powered up several more D-180's in-house and none of them have the yellow/red boxes around the digital number for gallons remaining in tank.
So, maybe I don't remember this correctly... Can anyone verify that they see yellow square and red square & red square blinking around gallons remaining digital number for a D-180? Also, do you get visual warning on bottom of screen for minimal gallons remaining (in my case - 4 gallons)? And while we're at it... do you get audible low fuel warning in your headset?
Maybe I'm getting too old for flying...
Old 05-28-2019, 05:05 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default D180
I ran my right tank low in my 8. My D180 goes green, yellow, red flashing, with audible and visual screen flashes.
Don
Old 05-28-2019, 07:28 PM
Piper J3's Avatar
Thanks guys. Today Dynon said they got their in-house D-180 fuel gage working correctly by re-loading Van's locked settings file. I'm going to put this task off until end of flying season. Good to know there's a fix...
