Clouddancer
I have a question for those who run a single electronic ignition (EI) and an conventional mag: How do you pick up the tach-signal?
We have a LSE Plasma III with a mini crank sensor and one Slick mag on the left side. We plan to use the Dynon Skyview for RPM display. The first thought was to use the LSE signal for display. But I assume that the tach signal will vanish during mag check when the EI is turned off. So do we need a to install a second tach sensor (in the mag or on the mechanical tach output)? As much as I understood the Skyview has two tach signal inputs that can be used. What is the solution that you preferred?
