w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-9/9A
  #891
Old 04-07-2017, 12:52 AM
PilotjohnS PilotjohnS is offline
Default after 10 months
After 10 months I have the tail feathers done and am working on wings. I am trying to spend 20 hours per week, but rarely can achieve that due to life, the universe, and everything else.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
Flying June 2023
www.pilotjohnsrv9.blogspot.com
or builders log here on VAF: Pilotjohns
Old 04-07-2017, 05:32 AM
Hornet2008 Hornet2008 is offline
I gave myself 2 years 5 1/2 years ago. Getting close.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 04-07-2017, 08:17 AM
airguy's Avatar
airguy airguy is offline
Heh, yeah, I had a 5-year build timeline laid out that I finished in 8. Life happens.
Garden City, TX VAF 2023 dues paid
N16GN flying 1,500 hrs and counting on 93E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 wing in process, full kit on hand, engine core purchased
Old 04-10-2017, 12:23 PM
ppilotmike's Avatar
My original schedule was also 5 years. Still working in year number 6, but with a healthy and mostly happy family at my side. I'm just hoping I wasn't off by a decimal place!
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 10-01-2017, 06:56 PM
Robert M's Avatar
Robert M Robert M is offline
Default First Engine start
Got the ground thingy squared away ( http://www.vansairforce.com/communit...d.php?t=152920 ). Had a couple of friends on standby with fire extinguishers, put power to all the necessary parts and the engine fired right up - no problems. I will need to adjust the carburetor idle a tad though.
https://www.facebook.com/Swashplate/...3394474243838/
Robert
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 10-02-2017, 01:11 PM
billieracing billieracing is offline
Default Wings On!
https://photos.google.com/photo/AF1Q...jTegRPeu89s8PM
Billie Racing
RV-9A, started 2015, finished 2018. 400 hours as of 2022.
RV-8 started 2020, finished .... almost...
The blood that flows from your finger after you run a #40 drill bit into it is proof that your still alive, cherish it.
Old 10-15-2017, 09:51 AM
dwranda dwranda is offline
Default Aluminum mistress has a nice tail!!
I got the tail all aligned and mounted over the last 2 days. It was a lot of fun and went fairly smoothly. Now to make the rudder stops. After that static ports installed. Then get the bottom wing skins riveted so I can mount those for the first time. Unfortunately my riveting partner is off at college so I'm going it solo. Maybe I can twist the wife's arm for some help!!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
9A
Airworthiness certificate received 12/1/2022
First flight 12/10/2022
phase 1 complete 5/18/2023
Mattituck TMXIO-360 red gold
Dues paid Dec 23
Old 10-15-2017, 10:02 AM
It's progressing nicely David. Hey if you have plans handy can you take a look at brass bushing specs? Inside the control column below the stick. Mine has an untolerable play and I want to machine a new one.
Old 10-15-2017, 10:27 AM
Snoho3 Snoho3 is offline
David,
Another question for you (thanks for posting the pics...). I see that you installed the ' Almost a -14 Mod'. I have done so as well. How do you plan to close/latch the right side of your canopy? I am not too sure about all the additional connections and linkages introduced by moving the long torque tube aft from its factory designed position. I am looking for alternatives and may just go with an independent latch on that right side corner of the canopy. What are your plans?
Thanks in advance - enjoy your Sunday!
Lars
Snoho3
RV-9A - Flying as of 12-20-2020
2022 Dues+ Paid and worth it.
Old 10-15-2017, 01:06 PM
Vlad, Is this what you're looking for?
[IMG][/IMG]
[IMG][/IMG]
9A
Dues paid Dec 23
