w/a Donation
VAF on Twitter:
@VansAirForceNet
  #1091
Old 09-04-2020, 05:50 PM
gmkonrad's Avatar
gmkonrad gmkonrad is offline
Default Vfr panel
Here is my example of a vfr panel.
Gary
Click image for larger version
Gary
RV-7 FLYING
N319GK
Old 09-04-2020, 09:24 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Gary
Nice uncluttered panel! I would like to do something similar for my VFR -6A.
Do you have any pictures that show the panel turned on? And is everything you need available on the primary display, or do you need to switch screens?
What are you using for a magnetic compass?
Thanks!
Paul.
Paul vS
Building RV-6A #22320 O-320 FP, slow build, 80% done.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 09-05-2020, 07:00 AM
Walt's Avatar
Walt Walt is offline
A nice VFR Garmin panel, this is an RV8 I did but you get the idea.
Here's another but an RV7, if you're on a budget just make provisions for the RH screen and install it later if you feel like,
2nd com/G5 is also optional.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, AFP FI, MTV-9 prop
Old 09-05-2020, 07:15 AM
Mel's Avatar
Mel Mel is offline
Thanks! Paul.
Most EFIS have an option for a magnetometer. Not sure about Australian rules, but in the U.S. the magnetic compass need not be independent from electrical power.
Mel Asberry, DAR since the last century. Over 1,100 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-05-2020, 01:40 PM
gmkonrad's Avatar
The compass is in the efis.
Here is the panel powered up.
https://photos.app.goo.gl/ytkTy9GuiDM95tzY9
Gary
Gary
RV-7 FLYING
N319GK
Old 09-05-2020, 06:33 PM
PaulvS's Avatar
Default Powered panel
Gary
Thanks Gary. Looks good.
Paul
Paul vS
Old 09-05-2020, 07:36 PM
Brdog42's Avatar
Brdog42 Brdog42 is offline
Default VFR -6
Paul,
This is what is going in our -6. AFS 4500, AERA660, GTX327 & A/P.
Adding G5 to finish autopilot.
ID:	2054  Click image for larger version
Tim
RV-6A restoration in progress
KCHD AZ
Old 09-05-2020, 09:15 PM
bhester's Avatar
bhester bhester is offline
Default My RV7A G3X Touches 😁
This was after upgrading from non-Touch to Touch
I’ve since changed some of the items along the top data fields, but have not taken a picture of the current setup. I do have my non-Touch screens for sale in the classified. Would be real good way to get a G3X system started.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2022 VAF donator - a lot better than any magazine subscription
Old 09-22-2020, 04:34 AM
Flavio Camelier Flavio Camelier is offline
Default My new G3X Touch VFR panel !
Actual flight this past weekend in the VFR corridors in the Rio de Janeiro terminal area.
Flavio
RV-7A (500 hours)
RV-10 sold
Instagram: @rv7pilot_from_Rio
Old 09-22-2020, 05:27 AM
PaulvS's Avatar
Default bomba
Nice panel! But what does the BOMBA switch do?
Paul vS
