w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-9/9A
Old 08-28-2023, 04:33 PM
hk1232's Avatar
hk1232 hk1232 is offline
Default Rivet Wing Ribs after match drilling skins
Working on my RV-9 now and I see the recommended sequence is to match drill, debur, then rivet the ribs to the spars before doing any work with the skins.
Seems like deburing and dimpling all the skin→rib holes would be easier if everything could be disassembled.
What am I missing that makes it worth doing most of the skin work with ribs in-situ?
Old 08-28-2023, 05:22 PM
wirejock's Avatar
wirejock wirejock is offline
Default Match drill
Because the skin is match drilled to the substructure after it's assembled. Then the skin is removed to prep
Deburring the holes is no problem. I used a 90 attachment with a speed deburring handle.
90 degree deburring tool
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2023, plus a little extra.
RV-7A #73391, N511RV Registered
Disclaimer
