Want to redo my camlok fasteners. Currently have camloks that sit slightly above the cowl surface. Would like to replace with something that sits flush. Is this possible without a lot paint/finish removale?
What series camloc do you have? If it's a 4002 series it appears the flush and plus flush grommets have the same diameter. So you should just be able to add the countersinks and not have to redo the paint. Although you will most likely have a bit of a halo around each camloc.
