Temp Hangar
I have space in a 54X48 box hangar at Faribault, MN (FBL) which is 3 miles south outside of the Minneapolis Class B airspace. The hangar has my RV6 in it but is otherwise empty...this means I could put about 6 more 2 place RV's in there. It has good lighting and electric with concrete floor but no heating or cooling with a 48' overhead bifold door. It seals well to the weather
FBL is about 250 miles west of OSH. You are welcome to store your RV9 there if you wish. Be advised that the airport was hit by multiple tornado's this past fall which destroyed 13 private hangars, many aircraft, the main City hangar, and damaged most city owned rental Tee hangars. Fortunately, my hangar was not even scratched which only a few occupants can say. While the runways and taxiways are functioning as normal, fuel is a problem now but should be resolved soon. The airport is located very near a ramp to Interstate 35 and is about a 30 minute drive to the South metro Twin Cities area.
Dick DeCramer
RV6 N500DD flying
RV8 sold
Email rv6n500dd at gmail dot com
Faribault, MN
