Old 10-12-2010, 12:22 PM
Flying Scotsman Flying Scotsman is offline
So two questions:
What the HECK do these acronyms stand for, anyway?
and
Does someone have a list of suggested or acceptable applications for the different types? e.g., it appears SCAT is recommended for engine compartment use, such as the cabin heat stuff; is there a chart or list that shows other options? Advantages/disadvantages? etc.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 10-12-2010, 12:28 PM
Auburntsts's Avatar
Here's an EAA video that explains it all:
http://www.eaavideo.org/video.aspx?v=46874087001
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 10-12-2010, 12:29 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Does this help?
http://www.hbdthermoid.com/aircraft_ducting.htm
Chris Smith
Sonex owner, RV wannabe....
Old 04-16-2021, 02:50 AM
dmattmul dmattmul is offline
Default SCAT tubing (Cuffed)
Yesterday I saw at SNF a airframe who's builder had used some sort of seemed SCAT tubing and it looked very nice and finished. Any idea who makes this? I assume it's ordered cut to length. Thanks
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived and now waiting (And waiting) for QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully 2022.
Old 04-16-2021, 05:33 AM
Default SCAT tubing found
Found it so good. Thanks
Old 04-16-2021, 06:46 AM
HFS HFS is offline
Default SCAT Tubing (cuffed)
Custom Duct
www.fairpoint.net/~kinney/
One of the better kept secrets in the corrugated hose business. At times, over the years, they have been located everywhere from the Northwest to the far East coast.
I have been using their service since the late 1980's, and have yet to replace a hose because of failed end conditions.
YMMV - And probably will.
HFS
Old 04-16-2021, 08:17 AM
John Tierney John Tierney is offline
If you're and EAA member, Dick Koehler did a good Hint for Homebuilders on ducting: https://www.eaa.org/videos/46874087001
If the URL doesn't work, log in to EAA then use their search function on "SCAT".
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 04-18-2021, 12:12 PM
Charles in SC Charles in SC is offline
Originally Posted by N941WR View Post
I found some stuff at the local auto parts store that is "custom made" for Van's RV's, just read the label:
You really need to get some Van's shoes and t-shirts to go with that.
RV 7
