Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 04-16-2021, 11:01 AM
Tracer 10 Tracer 10 is offline
Default Peter, Since you are batting 1,000 I have an O-Ring Question?
Originally Posted by pjc View Post
The small one is size 011. (Same size as used in the fuel drains typically).
Also available at oringsandmore.com (in BUNA or Viton).
Peter
I have an older RV6 with the Usher GAS-5 fuel sediment/filter bowl.
The O-Ring that was installed is obviously the wrong size and is seeping fuel under pressure from the electric fuel pump.
To you have a AN or MS number for the correct O-Ring.
Thanks a Million.
CW4 (Retired) U.S. Army
A&P: I pay double dues (it's worth it)
Restored L2-M; flown 7 years & sold.
Flying Oregon RV-6
Old 04-16-2021, 02:20 PM
pjc's Avatar
pjc pjc is offline
Thanks a Million.
I donít have an Usher Gascolator on my RV, so I donít know the proper O-ring size. It looks like Vans sells them however... try here:
https://shop.vansaircraft.com/cgi-bi...duct=gas1parts
That same page offers the replacement screen as well in case you need that.
If you measure the new o-ring carefully (OD, ID and thickness) there is a size chart at Oringsandmore.com that will tell you the numerical size designation.
Good luck,
Peter
Vans RV6 flying
SZD 48-2 sold
2018, 19, 20 Dues paid
