Old 03-19-2021, 07:06 PM
MacCool's Avatar
MacCool MacCool is offline
Originally Posted by Desert Rat View Post
I'm shamelessly hijacking this, but what sort of ferrule are you talking about? I agree with the OP that these are less than ideal, and would happily upgrade the end if I could find something reasonable to use.
I'm guessing this
https://www.youtube.com/watch?v=qUMyFbhy92c
RV-9A, 2011, bought flying
IO-320D1A
IFR certified
AFS 5400/3500, G5, 430W, some other stuff
Old 03-19-2021, 08:23 PM
bpattonsoa bpattonsoa is offline
Molex is the scourge of a wiring system, they have no excuse for existing. Radio Shack featured them, what more can you say?
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '89 (Sold)
HP-18 5596S flying since '83
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 03-19-2021, 10:04 PM
DTARM1 DTARM1 is offline
Default $400-$500
Molex / AMP connectors are kind of the GA standard. The problem is getting the correct crimpers which cost $400-$500. The $30 crimpers worked ok, but The single action, ratcheting crimpers that are specific to the gauge of wire/pin/plug made me laugh the first time I used them. There's nothing better.
I've seen bad Molex connections on components that cost $800,000 that were done with the wrong crimper in the part 135 realm. When I called the company and spoke with their DER about the bad crimps, he was unaware of the FAA requirement to use ratcheting crimpers designed for the specific connector.
The pictures in the first post are really sad - I wouldn't have that on my lawnmower.
Old 03-19-2021, 10:10 PM
hpmicrowave's Avatar
hpmicrowave hpmicrowave is offline
Default Molex
I've used Molex connectors for some 30 years and never had a failure, but I solider every wire to the Molex pin after I crimp it. It's a pain but it works.
Cecil "TRON"
RV8 N95CH In Phase 1 !!
RV6A Flying with Son Chris
Member, FlyOnSpeed Team
Sling 4 TSI Tail Done, Fuselage next
2021 Dues Paid, Home Field 18FD
Old 03-19-2021, 10:31 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Originally Posted by rv8ch View Post
I see them - copied here in case that helps. Buck, let me know if you are not ok with that.
Attachment 9479
Attachment 9480
Attachment 9481
I don't see the original pictures (or any indication that there is a picture) with the chrome or the new edge browser. They show up in firefox.
Ed
Old 03-19-2021, 10:42 PM
Originally Posted by emsvitil View Post
original pictures .
That last picture tells a lot.
Old 03-19-2021, 10:43 PM
That's quality work
Old 03-20-2021, 12:08 AM
BuckWynd's Avatar
BuckWynd BuckWynd is offline
To be VERY clear, these are sample photos of the type of connectors I'm referring to, not photos of my project!
Buck Wyndham
Northern Illinois
RV-8 N18XL
Old 03-20-2021, 06:03 AM
Walt's Avatar
Walt Walt is offline
Just curious what's the scope of your maintenance activities, a couple aircraft or hundreds? I do agree that if you take extra care with them it helps, but it's still a 2 cent connector prone to failure.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 03-20-2021, 07:03 AM
Skykingbob's Avatar
Default Connectors
So Walt....what are your connectors of choice?
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
